255/75/r17
Discussion in 'Wheels & Tires' started by Dsmooth87, May 24, 2012.
  1. Jun 13, 2012 at 4:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Tacomada nailed it. Tread pattern, tire weight, width and height all affect MPG. If you are only going to isolate tire height, going from stock height to a tire with the same tread pattern, relative weight and width but one series taller, you will see very slight gains on the highway under normal driving and, unless you're an aggressive driver, will not likely see any decreases in town.
  2. Jun 13, 2012 at 5:05 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Post up some photos if you can I'd love to see them.
  3. Jun 13, 2012 at 5:05 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Well of course it's not only tire height, it's A lot of things that comes into play. Weight, height, width. Just wondering how A taller tire gets you better MPGs, because mine got worse lmao.
  4. Jun 13, 2012 at 5:08 PM
    greenrustic
    NY
    That all makes sense. I know first hand, on my last tacoma when I went to a 10 ply LT (from a P rated) I had a reduction in mileage mostly due to weight.
  5. Jun 13, 2012 at 5:11 PM
    Pugga
    Massachusetts
    The reason is because any gains you would have gotten from the taller tires was negated by the wider tires. Your 285's are probably a lot more aggressive than your stockers and could possibly be an LT tire which means they're heavier. So you have a small height increase to help MPGs and all the rest of the factors to kill MPGs.
  6. Jun 13, 2012 at 5:35 PM
    Canuckwithatruck
    Canuckwithatruck Well-Known Member
    Ross
    Bow Lake, Alberta
    2006 TRD Sport
    OME 885 Coils Light Racing UCA's Dakar Leaf Pack
    Will do, they are going in with a set of LR UCA's, OME 885's and Dakar leaf pack.
  7. Jun 13, 2012 at 5:36 PM
    greenrustic
    NY
    What wheels?
  8. Jun 13, 2012 at 5:42 PM
    krimson
    krimson Nothin
    TRD Off Road
    yeah, it's my weight of my tires that's killing me. What I mean by my post was (long day), you do get lower RPMs with taller tires but you will have to apply more throttle to keep speed.
  9. Jun 14, 2012 at 10:30 AM
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    Yeah, like I said earlier, I am at higher RPMs around 70 MPH with 255/75 MTs than I was with 265/70 ATs. From what I read here though, most likely my speedo is off and I'm really pushing 75 or so. I guess I should get that recalibrated. But like he said, the tread pattern and extra weight definitely keeps me on the pedal more and thats why my MPGs were decreased a little. Still look badass though and perform infinitely better.
  10. Jun 15, 2012 at 1:53 PM
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    If your truck is in the same gear at a given speed the rpm will be the same regardless of tire size... This is easier to see in a manual trams. But if you were to lock the auto in 1st you could see that it is the same with different size tires. What changes is the actual speed you are going.
    A gps will be able to Give an accurate speed... Miata.net has an easy to use tire size comparison calculator that gives you the difference you would experience between tire sizes.
  11. Jun 15, 2012 at 2:13 PM
    Pugga
    Massachusetts
    WTF :confused:
    For a given speed, with the torque convertor locked or in a manual, the taller the tires are, the LOWER the RPM's will be at that speed.
  12. Jun 15, 2012 at 2:48 PM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    For actual speed yes. But the speedo won't know you have larger tires.... so your speed will be higher than the spedometer reads. Unless you recalibrate your speedometer to allow for the larger tire size. IF you just through on a set of 255/85/16 or 285/75/16 the speedo will read the same speed at 2k rpm as it did with 265's...
    Maybe I am way off here (someone give me a smack on the head if i am :smack:) i haven't changed the tire size on the second gen. But on my first gen everything stayed consistent. Pull out the GPS and the speed would be higher than what the speedo said with larger tires on.
  13. Jun 15, 2012 at 5:57 PM
    Pugga
    Massachusetts
    I was talking about actual speed.
    For the speedo to read the same with larger tires would depend on the gearing of the vehicle and I'm still not sure it would read the same speed with different sized tires.
  14. Jun 15, 2012 at 7:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The speedo would be calibrated to the OEM wheel size and how that related to axle revolutions , no ?
    The speedo would not change because you have bigger ( taller ) tires , but you would be going farther per revolution and therefore faster than the speedo reading , no ?
  15. Jun 17, 2012 at 10:03 PM
    #35
    deadbeat son
    deadbeat son Well-Known Member
    Denver, CO
    I run these tires on FJC steelies with stock suspension. No issues other than some slight rubbing at full compression while turning.
  16. Jun 18, 2012 at 4:08 AM
    #36
    greenrustic
    NY
    Did you have to do any trimming? Did you remove your mud flaps?
  17. Jun 18, 2012 at 5:40 AM
    #37
    Pugga
    Massachusetts
    Yeah, I suppose you're correct. I think I confused myself once the speedo read out came into the mix :eek:
  18. Jun 18, 2012 at 8:36 AM
    #38
    deadbeat son
    Denver, CO
    No trimming at all. I still run 3 out of 4 mud flaps. One of the front flaps was ripped off by an obstacle off road, it had nothing to do with the tires.
  19. Jun 18, 2012 at 8:48 AM
    #39
    98tacoma27
    Ben
    Not Beech Creek
    No, the speedo changes. I went from 265/70-16 (30.5") to 255/85-16 (33") and
    my speedo was 5 mph SLOWER than actual speed.
    Your RPMS will change, but you probably won't notice it on the needle. It will even be difficult to register on a UG or Scan gauge, depending on gear ratio.
  20. Jun 18, 2012 at 9:14 AM
    #40
    deadbeat son
    Denver, CO
    Also of note, the FJC steel wheels I am running these tires on have less backspacing than the Tacoma wheels, so they sit about 1/2" farther out from the frame and suspension.
