$261 for brake pads and rotors question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Backt, Jul 5, 2021.
  1. Jul 7, 2021 at 7:22 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Went with slotted , drilled rotor's with HD pads from Detroit Axle on Amazon. At my door for 140.00 , two years and 26000 miles ago. No problems, work fine, little dust but not out of line...
  2. Jul 7, 2021 at 9:51 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Hey buddy, next time maybe brake the Xanax in half before posting. Not everybody is looking for an upgrade that involves a huge ordeal. The OEM brakes work fine, are you racing NASCAR every weekend? Sure the Taco brakes aren't the greatest but they get us by. By your logic you might as well put a diesel or LS engine in there while you're at it because the OEM wasn't up to your standards.
  3. Jul 12, 2021 at 10:34 PM
    Backt
    Backt [OP] Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I’m planning on replacing them tomorrow. Is there anything wrong with buying a shim kit from a auto parts store vs the dealership?
  4. Jul 12, 2021 at 10:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Shims are shims for the most part. How are the originals? Reusable? If they're not bent just swap them over to the new pads
  5. Jul 12, 2021 at 10:43 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    OP you’re going to need some custom carbon ceramic brakes with a disc conversion rear, and a parachute for when slowing down from really high speeds. Also recommend you permanently roll down your passenger window, have a an anchor with a chain running to the rear of the frame and just weld the chain where ever works so you can drop the anchor whenever needed.
    6 gearT444E and b_r_o like this.
