265/65/17 or 265/70/17
Discussion in 'Wheels & Tires' started by LMR, Nov 17, 2011.
  1. Nov 17, 2011 at 7:10 AM
    LMR
    LMR [OP] GO JETS GO
    Lee
    In The True North
    2008 Tacoma DCSB TRD
    Shorty antenna, Weathertech digital fit, tonneau cover
    Any preferances on which size to go with? I've decided on the Hankook Dynapro ATM RF10 tires. 08 Double cab SB with stock suspension.
    Need some help from TW. Thanks..
  2. Nov 17, 2011 at 7:11 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    what are you trying to accomplish?
  3. Nov 17, 2011 at 7:14 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    265/70
  4. Nov 17, 2011 at 7:21 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    265/70, but I did lose 1-2 MPG.
  5. Nov 17, 2011 at 7:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    265/70 and I actually get slightly better mileage on the highway, no change around town.
  6. Nov 17, 2011 at 7:42 AM
    LMR
    LMR [OP] GO JETS GO
    Lee
    In The True North
    Nothing. Just daily driving. Lots of snow where I live if that's relevant.
  7. Nov 17, 2011 at 8:40 AM
    OZ-T
    Peter North
    British Columbia
    Yes , 255/75/17 is an option , and better for snow in general , but less common .
  8. Nov 17, 2011 at 8:43 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    265/70
    Where's the poll??? :D
  9. Nov 17, 2011 at 6:00 PM
    CableTec
    CableTec Legend in my own mind
    J-ville and P-ville, FL
    2007 V6 PreRunner SR5 TRD
    See sig.....
    ^^^^^This
  10. Nov 18, 2011 at 6:00 AM
    LMR
    LMR [OP] GO JETS GO
    Lee
    In The True North
    What's the benefit of going to 265/70 tires?
  11. Nov 18, 2011 at 6:02 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    05 Taco 4x4 SR5 TRD AC
    Ive got the hankooks in 265/70/17. They rub the plastic liner since my wheels have such a high offset. They were fine on stock wheels.
  12. Nov 18, 2011 at 6:04 AM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    One benefit is that it is a slightly larger diameter and will reduce the rpm's you turn when on the highway. They also fill the wheel opening nicely
  13. Nov 18, 2011 at 7:29 AM
    OZ-T
    Peter North
    British Columbia
    Looks better
  14. Nov 18, 2011 at 7:38 AM
    PB65stang
    Patrick
    Kansas City
    Will probably technically true, my guess is that any benefit this would give would be negated by the extra effort the engine needs to move the extra weight of the tire.
    EDIT: They do look MUCH better though.
  15. Nov 20, 2011 at 10:44 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    They are actually cheaper than the stock 265/65/17 size, go figure!
  16. Nov 20, 2011 at 10:44 AM
    NC15TRD
    Nick
    PA
    255s are actually lighter weight
  17. Nov 24, 2011 at 6:10 AM
    LMR
    LMR [OP] GO JETS GO
    Lee
    In The True North
    won't I get better fuel economy with the 265/65/17 tires?
  18. Nov 24, 2011 at 7:35 AM
    Pugga
    Massachusetts
    Depends on how you drive. I actually do a little better unloaded on the highway with the taller tires.
  19. Nov 24, 2011 at 8:26 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    and your spedo will be spot on with the 265/70 series tires. Not sure with the 255s. If it were me I would get whatever is cheaper.
    I cant wait till my stock tires are worn out so i can go with a larger tire! its gunna be geolanders for me.
  20. Nov 24, 2011 at 7:18 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Between 265/65, 265/70 and 255/70 they are all a bit of a toss up in terms of MPG what matters more is brand and tread design.
    A highway tread tire is going to get better mpg of course vs a all terrain or a mud terrain obviously.
    I want a AT tire but dont want to drop a bunch in MPG so this is done by buying a P metric tire which has less tread depth typically by 2/32's and a thinner sidewall vs a Light truck / LT tire. Of course if you tow or off road alot a LT tire is the correct choice.
    The other variance is weight look at the weight of each tire. The stock tire depending what yours came with can be as low as 36-37 pounds a tire.
    Some AT tires are 50 pounds and some are 38 pounds for same size just different brand and tread design. Just make sure you look the weight is the main thing that will kill the mpg since it is rotating mass and not dead weight.
    I personally am going with the new BFG rugged terrains in 265/70/17 since they weigh in at 39 pounds and look good. I do not want a loud AT tire either. This one is techinically a HT tread design.
    I had the original bridgestone revos in p metric and they were 40 pounds but the truck road like crap for some reason. Very stiff. I would go with them again but do not want such a stiff ride again.
