265/75/16 Tire pressure ques
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NS TRD, Jul 30, 2011.
  1. Jul 30, 2011 at 9:03 AM
    NS TRD
    NS TRD [OP] Member
    I just put 4 new BFG 265/75/16 Mud terrain KM2 on my 08 Tacoma access cab TRD...when i left the tire place everything was fine...but after an hr or so of driving my tire pressure light came on..and has stayed on since....what pressure should i be running in these to put the light out?for the stocks it calls for 29 in the front and 32 or something in the back?but these are bigger tires...so i'm unsure if it would be the same or not
  2. Jul 30, 2011 at 9:11 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Depending on the year of your truck you might have a sensor in the spare too. Check that all tires are the same psi and re-set the TPMS to what ever pressure you decide to go with. For the correct pressure do the chalk test. If a re-set doesn't fix it they might have damaged one of the sensors.
  3. Jul 30, 2011 at 9:17 AM
    drifter379
    drifter379 CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
    Chalk test?
  4. Jul 30, 2011 at 9:27 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This ^^
  5. Jul 30, 2011 at 9:37 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes... adjust the pressure for your new tires, then RE-SET the TPMS! How to do it is in your owner's manual!! It is easy to do.
    Chalk test is to chalk a wide line across the tread, then drive a hundred feet or so... Examin the chalk left on the tread...
    You want even wear across the tire.. If only the center rubbed off... TOO MUCH air.
    The pressure listed on the sidewall is the max. pressure (for max. load carrying) and not the normal pressure you want to run, typically.
    My truck door jam says (with Rugged Trails, when new) 29 psi front and 32 psi rear... When I changed to a better tire with a 44 psi max. rating, I found 32 to be too soft and 36 felt fine... I have not done the chalk test myself.
