265/75/R16 and Toyota
Discussion in 'Wheels & Tires' started by SeniorSpan, Jan 22, 2012.
  1. Jan 22, 2012 at 10:51 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    11 Silver 4wd TRD DC TXpro
    Tire Garu's,
    If I understand things correctly, one of the conclusions one can draw from the numerous tire size for stock suspension Tacoma's sporting 16 inch rims is, 265/75/R16's fit just fine without rubbing.
    That being the case, why doesn't Toyota show the 265/75/R16 as an alternative/optional tire? Or am I missing something real obvious here?
    Thanks
  2. Jan 22, 2012 at 10:58 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Maybe they don't want to give the option. Why change a good thing.
  3. Jan 22, 2012 at 11:05 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Maybe on stock wheels, from my readings I've found that with aftermarkets they won't. I've been asking this question and haven't really gotten an answer. I'm about to put 16x8's on my truck and have been told by members with the same wheels that they will scrub and will need to trim. So I'm planning to stay with the stock size. Wish I knew for sure before I buy my tires. I know the offset and backspacing will change things. I'm putting on 16x8 Moto Metal w 0 offset and 4.5 bs.
  4. Jan 22, 2012 at 11:07 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I have 265/75R16 MT's and had mine on after market moto metal's and had to take the front mud flaps off but after I did that I had 0 rub. I have the TRD Beadlocks now and still no rub.
    JaCado likes this.
  5. Jan 22, 2012 at 11:07 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I'd imagine they don't show it because it is bigger than the original tires, and gives you worse gas mileage.
  6. Jan 22, 2012 at 11:08 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    :confused:U can fit 265/75/16 w/ that setup.
  7. Jan 22, 2012 at 11:09 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    you know those numbers on the sticker, the MPG....they want those to go higher not lower!
    larger tires= more rotational mass= more work needed by the motor= worse fuel economy
  8. Jan 22, 2012 at 11:11 AM
    TacoDawgfan
    Georgia
    With no lift or leveling kit?
    ToyotaComer2015 likes this.
  9. Jan 22, 2012 at 11:18 AM
    bridgcat
    Alabama
    Yup....you're good to go. Just take the front flaps off and you shouldn't have any problems.
  10. Jan 22, 2012 at 11:21 AM
    TacoDawgfan
    Georgia
    I know it would look better but I really like the protection of the flaps though.
  11. Jan 22, 2012 at 11:22 AM
    bridgcat
    Alabama
    I think some folks have kept their on and just cut them or shaved them a little to keep from rubbing.
  12. Jan 22, 2012 at 11:24 AM
    Dustyroades
    Dustyroades Well-Known Member
    Ontario
    '09 MGM AC 4x4 SR5 2.7L 5spd
    Front Bilstein 5100s at 1.75", rear 1.5" AAL w/ TSB and OME N182s, P265/75R16 Hankook A/Ts
    Sure but it also equals a lower effective gear ratio. At cruising speed this can result in a fuel economy increase, as long as the tire is not a heavy LT. Going from P245/75R16 to P265/75R16 has not noticeably affected my MPGs.
  13. Jan 22, 2012 at 11:27 AM
    08pretaco
    Oliver
    az
    toyota is looking for a balance of power and economy, apparently they came up with the "ideal" set-up. I am under geared right now, which is what the larger tires and factory gearing would be like for the OP. At cruising speeds yes I am at low RPM but it feels as if the motor is working harder and certain points to keep me going at a certain speed.
    For instance, I was over geared with 4.56 and 255/85/16. Now I am undergeared with 4.56 and 315/75/16. I get the same fuel economy as I got with the previous set-up at the expense of my power which has noticable decreased.
    Those values are for a 4 cylinder just to throw that out for correct info.
    Also to add: in theory YES you should get better fuel economy but with a lot of other vairables such as weight with rotational mass I do not think the real follows the ideal in this sort of situation.
  14. Jan 22, 2012 at 11:28 AM
    TacoDawgfan
    Georgia
    Yeah I was also planning to stay with the 265 70 16 to try to not hurt mpgs. I've read on here to expect to lose 1-2 mpg if I go to the 75's. Since I'm not lifting then I figure why kill the mpg?
  15. Jan 22, 2012 at 4:31 PM
    SeniorSpan
    Bob
    Colorado Springs
    Thanks for all the info; lots of food for thought.
    I appreciate everyone's time.
    Cheers
  16. Nov 28, 2014 at 5:24 AM
    BayRanger
    BayRanger Well-Known Member
    Southeast
    2012 DC PreRunner SR5 2.7L I4
    I'm about to put these on my stock 2012 prerunner DC. I'll let ya know. They're $82 each so I can't pass them up.
  17. Jan 13, 2015 at 5:50 PM
    surforegon
    surforegon Well-Known Member
    Bone stock (unlifted and stock alloy wheels) 2015 4x4 Doublecab TRD OffRoad and just put 265/75R16 Wintercat SST studded tires on. No rubbing at all, and the stock mudflaps are on.
    Also road tested the speedometer vs a Garmin Oregon GPS and speed was dead nuts exactly the same.
    mchalmers, Bigskybob and spinglow like this.
  18. Jan 13, 2015 at 6:23 PM
    BayRanger
    Southeast
    Freakin Walmart refused to put them on my truck and I was pressed for time so I went with Wranglers in the factory size. Oh well.
  19. Jan 14, 2015 at 8:05 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '16 Tacoma DCSB TRD OR
    OME & 285/75R16 plus other stuff.
    They told me that as well, they told me it was a liability issue if they don't put on a factory size tire.
    I wanted to put 265-70R17s on my 4Runner with a 2/1" leveling lift. (factory is 265/65/17)
    I got my tires from BJ's, but they gave me an issue as well. But we ended up ordering them as "FJ Cruiser" replacements" in their computer system.
  20. Jan 15, 2015 at 10:09 AM
    zoblo
    zoblo Active Member
    03 extra cab trd v6
    I have 2003 4wd tacoma extra cab with stock suspension. I just put on some new bfgoodrich T/A K02's, 265/75/16 from discount tire and they rub a little bit on the front mud flaps and plastic fender liner when making a sharp turn. Deciding whether to take them back or not worry about it.
