265/75R16 smaller than 305/70R16?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JessLuvs2Romp, Jun 10, 2015.
  1. Jun 10, 2015 at 9:10 AM
    JessLuvs2Romp
    JessLuvs2Romp [OP] Member
    stock as fock
    These 305/70R16's claim a diameter of 31.7," while these 265/75R16's are 31.9." I've seen a bunch of pics of these particular 265/75R16's fitting a stock taco just fine..
    Could I run these 305/70R16's on zero lift and stock rims? Or would there be too much rubbing because of the width of the tire? I'm willing to remove mudflaps and do a small amount of cutting.. I also have some 1.5" spacers I plan to slap on..
  2. Jun 10, 2015 at 9:18 AM
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    With spacers they might work but my 265/75r16's come really close to rubbing on the inside of the tires sidewall. The first 3 numbers show you the width. 305 is a pretty wide tire that probably wouldn't fit on stock rims.. I'm probably going to 235/85/r16 tires on my next set for a few reasons but partly so I can run truck chains on the front again without spacers..
  3. Jun 10, 2015 at 9:25 AM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    Yeah they would probably rub the upper control arm without spacers. The math says that they are 32.8" so I'm guessing their info is off.
  4. Jun 10, 2015 at 9:36 AM
    JessLuvs2Romp
    stock as fock
    it says the same info on the pro comp website also..
  5. Jun 10, 2015 at 9:39 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    With enough cutting, spacing, and tolerance for rubbing, you can make anything fit on anything.
    This isn't a configuration I'd recommend, however.
  6. Jun 10, 2015 at 9:40 AM
    jessandjamie
    Arizona
