275/65/17 rubbing
Discussion in 'Wheels & Tires' started by myamada1230, Jun 26, 2012.
  1. Jun 26, 2012 at 6:26 PM
    myamada1230
    myamada1230 [OP] Well-Known Member
    Greenacres, WA
    2016 TRD Off road short bed 6MT
    Hello,
    I am going to be purchasing new tires and a 2" leveling kit soon. I was wondering if anybody has put a 275/65/17 or a 275/70/17 on OEM wheels on a 2nd gen Tacoma with a 2" level. If so, did you have any rubbing issues with OEM TRD sport wheels? I have seen alot of guys do 265/70/17 with no rubbing issues.
    Thank-you!
  2. Jun 26, 2012 at 6:30 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I run 275/70/17 on stock Sport alloys with 2 1/2" of lift , no rub
  3. Aug 9, 2012 at 12:47 AM
    myamada1230
    Greenacres, WA
    OZ-T, Did you have to remove your mudflaps for this size tire not to rub?
  4. Aug 9, 2012 at 12:52 AM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    RainForestVille, Honolulu, Hawaii
    '11 BLK Tacoma PreRunner TRD SR5 Access Cab
    See Signature.....
    If you run wider than 17x9 wheels you will rub.....:eek:
  5. Aug 9, 2012 at 12:54 AM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    See Signature.....
    You'll need to remove your front mud flaps.....:rolleyes:
  6. Aug 9, 2012 at 1:36 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I have stock TRD sport wheels with 275/70/17 Cooper Discoverer AT3 tires. My left tires rubs the front inside edge of my fender and the tiniest corner of my UCA at full left turn. No other rubbing. My right wheel in fact does not even rub at full left turn. Everything has been aligned by the dealership and it rides awesome. I just avoid the full left lock. It is really so slight I doubt I would even get spacers.
  7. Aug 9, 2012 at 2:24 AM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    I'm running 275/70/17 wrangler ats.I think im rite around 2.5" of lift with no issues. I did ditch the mudflaps but only because I ripped 2 of the off wheeling in WV.
  8. Aug 10, 2012 at 5:59 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    275/65/18 with 1.75" lift here, minor trimming
  9. Aug 10, 2012 at 8:35 AM
    OZ-T
    Peter North
    British Columbia
    No I didn't :rolleyes:
  10. Aug 10, 2012 at 8:41 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I was running 275/70/17 on FJ 17" wheels with a 2 1/4 spacer lift with no rubbing at all, even with mudflaps.
