275/70/16 -or- 265/70/16
Discussion in 'Wheels & Tires' started by Troyton, Feb 28, 2013.
  1. Feb 28, 2013 at 4:45 PM
    Troyton
    Troyton [OP] Well-Known Member
    Troy
    South Florida (Naples)
    06 DoubleCab PreRunner "Wanna be XSP"
    -Trd shocks -Clifford Alarm System -Kenwood Radio -Led bars -Green Fog Lights -2010 Head lights and Tail lights -2010 Tail gate with Back up Camera -White Dash Mod -2011 grill -Led Pods -Kicker Subs -PA System - Underglow
    06 Tacoma V6 TRD package.
    With a 3 inch lift, and stock tires painted black, should i go with 275/70/16 or 265/70/16 ? I do not like a truck with an uneven look. The tires should look good with the lift. Please, I need suggestions.
  2. Feb 28, 2013 at 4:46 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Who makes a 275/70/16 ?
  3. Feb 28, 2013 at 4:48 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Why not 265/75/16? 265/70/16 should be stock size for an OR.
  4. Feb 28, 2013 at 4:48 PM
    68Whiskey
    68Whiskey Well-Known Member
    Richie
    Ft.Bragg NC
    2008 4x4 DC TRD Off Road
    265/70 or 265/75 and 285 would be a lot easier to find than a 275 size tire.... I kinda had the same reaction as OZ-T did
  5. Feb 28, 2013 at 4:55 PM
    OZ-T
    Peter North
    British Columbia
    I have 275/70/17 , haven't seen 275/70/16 though
  6. Feb 28, 2013 at 5:00 PM
    Troyton
    Troy
    ok, what exactly does the 75 or 70 stand for?
  7. Feb 28, 2013 at 5:12 PM
    TacoGuy171
    TacoGuy171 Well-Known Member
    Dan
    Manitoba
    05 SR5 TRD
    Width of tire in metric
  8. Feb 28, 2013 at 5:16 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Not width, aspect ratio. (height)
  9. Feb 28, 2013 at 5:16 PM
    OZ-T
    Peter North
    British Columbia
    To help you understand tire sizes a little better here's a quick lesson.
    For an example we'll use a fairly common tire size for trucks with a 3" lift, a 285/70/R17.
    We'll first label the parts as follows:
    285/70/R17
    _^__^__^
    _A__B___C
    A- This is the width of the tire in millimeters. The conversion is 1"= 25.4mm so for our example: 285/25.4= 11.22" width.
    B- This part is the "aspect ratio" of the tire and is a relation of the tire's width to the sidewall height of the tire. In our example it's '70'. This means the sidewall height is 70% (.70 in calculation) of the width of the tire. That means the sidewall height is:
    11.22 x .70= 7.85"
    BUT there is a 'sidewall' both above and below your wheel when measuring height, so you must multiply this by 2 when calculating the tire's overall height.
    C- This third piece is simply your rim size. So, for a final calculation of a tire's size, you add this to the total from part B.
  10. Feb 28, 2013 at 5:16 PM
    jtav2002
    Josh
    Reading, PA
    Its the height of the sidewall if you're talking the middle number.
    EDIT: oz beat me with a much more thorough explanation haha.
  11. Feb 28, 2013 at 5:20 PM
    OZ-T
    Peter North
    British Columbia
  12. Feb 28, 2013 at 5:23 PM
    Willcrowe22
    Willcrowe22 New Member
    Alabama
    12 tacoma prerunner sr5 access cab
    flow masters exhaust, westin nerf bars, bull bar, low pro tool box, 2'' leveling kit so far.
    will a set of dick cepek 16x8 with 265x70x16 tires fit on a 2012 Tacoma prerunner sr5 without rubbing?? really needing to know???
    rim specs are
    16x8
    4 backspace
    -12 offset
