275/E vs. 285/D vs. 285/E
Discussion in 'Wheels & Tires' started by Relik, Aug 1, 2011.
What size/load?
Poll closed Aug 31, 2011.
  1. 275/70/17-E
    1 vote(s)
    6.7%
  2. 285/70/17-D
    8 vote(s)
    53.3%
  3. 285/70/17-E
    5 vote(s)
    33.3%
  4. Stay Stock Size
    0 vote(s)
    0.0%
  5. Other, see below
    1 vote(s)
    6.7%
  1. Aug 1, 2011 at 2:44 PM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey guys,
    I just hit a road block in my tire selection. i'm getting Eibach springs @.85(5100s) + half inch spacers, 1.5" or 2" AAL for TSB, Spidertrax 1.25" wheel spacers so i can fit 285/70/17 tires on my Sport 17" Alloys.
    My Final selection was BFG all terrain kos 285/70/17-D, but it only comes in Black Sidewall!
    I really wanted the White Sidewall, but its only available for E load (Also 275/70/17- E load). Based from Tire rack, the weight of the E load is 3 lbs more per wheel, tho the 275-E load is 1lb less per wheel. Could be that 275 would prevent lil more probs that 285, plus it weighs less...
    Help! lol....is E rated that harsh of ride to sacrifice looks/size? I was really set I wanted these tires to pop with the sidewall but I must choose soon.
    Thanks,
    Eddy
  2. Aug 1, 2011 at 2:54 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    I wouldn't worry about 3 lbs difference in weight.
    Where do you drive? If always on the road, get the softer ride.
    I am on crushed gravel roads every day where cars get flats all the time. I go with E rated tires which hold up much better.
  3. Aug 1, 2011 at 3:45 PM
    Relik
    Eddy
    Thousand Oaks, CA
    I see yeah I'm a 99% highway driver, and will do trail runs like average once a month.... so this whole feelin better about the letters lookin cool but bad about the ride isn't pannin out lol.
  4. Aug 1, 2011 at 3:55 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    255/80/17 E
  5. Aug 1, 2011 at 4:13 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    I've got the E rated BFG A/T's and don't mind the ride at all. Going from the p rated BFG rugged trails the handleing is way better with the stiffer sidewalls and doesn't follow the ruts in the road like the p rated did. The truck seems more stable and doesn't feel like I'm leaning into the corners anymore. I'm running 36 psi front/ 34 rear.
  6. Aug 1, 2011 at 4:58 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    F-that, I wouldn't put E rated tires on a truck as light as a Tacoma. It'll ride like a dump truck. D is even overkill by far but would ride slightly better. The Eibach/5100's ride stiffer than stock anyways, throw on a much much stiffer tire and it'll ride like a hay wagon. Just my $0.02, good luck, I wouldn't put them on my truck!
  7. Aug 1, 2011 at 5:00 PM
    OZ-T
    Peter North
    British Columbia
    I've been running E-rated Hankooks for 2 years , no problem
  8. Aug 1, 2011 at 5:02 PM
    Relik
    Eddy
    Thousand Oaks, CA
    Well good to hear its not terrible hehe. I felt this conrering change when switching to Bilstein 5100s. Hm this is a toughie, I do have a prerunner too so more under the load rating.
    And aren't those 255s pizza cutters? lol
  9. Aug 1, 2011 at 5:04 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  10. Aug 1, 2011 at 5:06 PM
    Pugga
    Massachusetts
    Not saying it'll cause problems, they'll work fine as far as tires go but they will certainly ride rough! I'm constantly in the city so that's probably what's driving my bias opinion. Lots of very bumpy and choppy roads, no way I'd want E-rated tires. If you're in the country and/or tow and haul heavy then go for it. E-rated is still overkill in my opinion.
  11. Aug 1, 2011 at 5:08 PM
    OZ-T
    Peter North
    British Columbia
    Sometimes that is your only option in certain tires and sizes
  12. Aug 1, 2011 at 5:13 PM
    Pugga
    Massachusetts
    I know what you mean, I've been looking for a narrower tire for my 17" stock wheels and and running into that issue :(
  13. Aug 1, 2011 at 7:04 PM
    OZ-T
    Peter North
    British Columbia
    Me too , and I'm certain I'm going 255/80/17 next set
  14. Aug 2, 2011 at 1:40 AM
    Relik
    Eddy
    Thousand Oaks, CA
    What's the pros vs cons of an inch narrower tire? Is it mainly to avoid using spacers? Any better on highway? offroad?
  15. Aug 18, 2011 at 9:42 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    OK, I 1 million percent disagree with everything Pugga just said. I have the Eibach springs with 5100's at .85 and my ride is TONS more comforable on the road than stock. I also have the rear TSB with Toytec AAL with 5100's in back to. I also happen to be running BFG AT KO's 285/75-16 and at 35-40 psi they ride great, you dont feel a single bump in the road, they ride butter smooth. I pumped them up to 50psi for more milage on the freeway and I do feel every little tar snake in the road but its still not a bad ride.
    I air them down to 18-20 psi to wheel and they do great. I have 7k miles on mine and they are starting to get chewed up because I wheel the shit out of them but its a great set up, its better than stock, and you will have no problem with it at all.
