285/70/17 fitment with stock rims and 1.25 spacers
Discussion in 'Wheels & Tires' started by emilminasian, Sep 2, 2013.
  1. Sep 2, 2013 at 2:54 PM
    emilminasian
    emilminasian [OP] Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    I'm currently running stock tires with stock 265/65/17 tires I also have 1.25 spacers installed with 2.5 inch lift on LR UCAS will I be able to run 285/70/17s with stock rims ?
  2. Sep 2, 2013 at 7:42 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You definitely can! You might need to remove your mud flaps if you haven't already.
  3. Sep 5, 2013 at 1:57 PM
    emilminasian
    Emil Minasian
    Glendale, CA
    Would I have to trim anything? Mud flaps are already removed
  4. Sep 5, 2013 at 1:59 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Most likely just a little trimming on the plastic wheel well liner specifically right behind the front bumper. Any trimming needed will be easy to take care off.
  5. Sep 5, 2013 at 2:00 PM
    T1no33
    T1no33 Well-Known Member
    Spring Hill, Fl
    2012 PreRunner V6 SR5
    - Partial Badge Removal & Dipped - Removed Mud Flaps - Blacked out Emblem - Blacked out Chrome Surrounding Grill - Salex Center Console Organizer - AntennaX 13" - Tinted Front Windshield - Derped Tacoma Emblems - Bridgestone 265/70/16 tires - Tuff AT Wheels - 3 and 1 spacer block lift (mistake big time) - Black Rear Bumper - Aries Bull Bar w/light rig
    X2
  6. Sep 5, 2013 at 2:01 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    they will fit just fine in relation the the suspension components. your potential areas for rubbing and trimming are the cab mount, inner fender well, and fenders/flares. your alignment will have a good amount to do where and how much you hit, as well at the tire itself, as they vary in size by brand and modle. some people have had to cut a lot, others none. plan for the worst, hope for the best. you should be just fine for street driving though, without trimming.
  7. Sep 5, 2013 at 2:14 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Let us know how it goes. I have a "3 inch" level kit and the spidertrax and my alignment guy said that I could not run anything more than 265/70/17...........given that I do have stock wheels and upper and lower control arms.
