285/70/17..looks great but...they rub
Discussion in 'Wheels & Tires' started by BajaTaco, Jun 14, 2011.
  1. Jun 14, 2011 at 4:02 PM
    BajaTaco
    BajaTaco [OP] New Member
    Huntersville, NC
    2011 TRD Access Cab 4x4
    3" ReadyLift CBI Tire Carrier
    I want to share my somewhat frustrating experience with wheel and tire selection. I decided on:
    285/70/17 Goodyear MT/R Kelvar tires
    17x9 KMC XD Addict wheels -12 offset
    My truck is a 2011 4x4, access cab, TRD Offroad
    3" ReadyLift lift kit
    Bushwacker pocket style fender flares
    I had to remove my mudflaps and trim a substaintial amount of my fender liners and some of my Bushwacker fender flares. Despite all this trimming and a 3" lift, my front tires rub. The rubbing occurs on frame at near full-lock turn and it makes an annoying noise.
    So....I sort of wish I had chosen 16" wheels instead of 17s. I really like the look of the 285 width but at 70 series they are about 1/2" too tall.
    Has anyone tried 285/70/16s? I think they might be perfect. I realize that there are not many choices in 285/70/16 other than the Nittos.
    Would spacers or a different offset help?
    I spent a fortune on five new wheels and tires so this rubbing is a drag.:mad: Be warned about 285/70/17s..at least the GY Kelvars!
    http://www.tacomaworld.com/gallery/uploads/53920/tire_carrier_012.JPG
  2. Jun 14, 2011 at 4:06 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    You just need some more lift. My 285's never rubbed with the Toytec kit. Now that I've gone to a RCD kit I can clear larger ones.
  3. Jun 14, 2011 at 4:18 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    Are you sure the lift is at 3" I ask because im at 3" and running 285/70-17's and only rubbed on mud flap. I do rub ever so lightly on front little bump of wheel well only in reverse full lock. I have not cut anything
  4. Jun 14, 2011 at 4:20 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    They are going to rub on the frame unless you get some different rims. What is the BS of your wheels? Its not that big of deal, my tires rub the frame, just dont turn so sharp if it makes you angry. I dont really care, its not hurting anything and the only time i turn super sharp is offroad.
  5. Jun 14, 2011 at 4:37 PM
    BajaTaco
    Huntersville, NC
    Thanks for the replies...
    jrobson...will more lift move the tire further from the frame? (sorry..maybe stupid question..I am not sure how the lift affects the frame clearance)
    Sheppy: yes, a 3" ReadyLift, not just the leveling kit
    Rebel: different wheels? my 17x9s are -12 offset which is 4.5BS
    thanks for your thoughts!
  6. Jun 14, 2011 at 4:40 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    I rub my fender a bit even with my 4 inch spindle lift with 285/70/17... I haven't trimmed. Don't worry about it. If it is really bugging you just get a cab mount chop.
  7. Jun 14, 2011 at 4:41 PM
    jandrews
    '09 FourDubDee TRD OR
    Yes. Yes they do rub.
  8. Jun 14, 2011 at 4:51 PM
    Rebel Taco 22
    With more BS. Something like 4. But just learn to deal with it, its really not a big deal. It bothered me at first but i just learned to deal with it and its not a big deal anymore.
  9. Jun 14, 2011 at 4:53 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    just start trimming and make the tires fit
  10. Jun 14, 2011 at 4:59 PM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
    I run 33x12.50 17's which are about an Inch wider than 285's. I had to chop the body mount and trim the rear of the front fender. But I only chopped and cut for off road use. I have the toytec 3" lift with 885 springs and a 220Lb bumper. My truck doesn't and never has rubbed the frame. My wheels are 17x9 Addicts with 4.5bs, even at full lock I don't touch the frame. Are you sure your not rubbing on the body mount?
  11. Jun 14, 2011 at 5:00 PM
    2011TacoSport4x4
    Clyde
    +1:D
  12. Jun 14, 2011 at 5:02 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Mine rub.... Remember when modding there will be cons.... Modding isn't always gonna be just like stock you will sacrifice gas mileage, rubbing, etc..
  13. Jun 14, 2011 at 5:23 PM
    BajaTaco
    Huntersville, NC
    rebelT: yea, you're right, it's not a big deal..i'll get used to it
    2011TocoSport: the rubbing occurs on the tip of the frame section (shaped like a heal of a boot) where the body sits.
    Krimson: yep, modding is new to me and I have a lot to learn, but it's fun! You are also right about the negative impact on gas milege!
  14. Jun 14, 2011 at 5:30 PM
    Rebel Taco 22
    Ohhhh that makes sense that its on the body mount. I thought it was on the boxed in part of the frame. My bad, different BS wouldnt make a difference. Check out the the body mount chop if you really hate the rubbing.
  15. Jun 14, 2011 at 5:34 PM
    krimson
    krimson Nothin
    TRD Off Road
    The wheels and tires aren't really the issue, they are just fine (when running 285s with a 2.5+ lift) what you are experiencing is a common problem with running 285s on these trucks. They look just right, for the truck but they rub like a bitch with out trimming shit. You will def have to do the cab chop mod. Truck looks great though :thumbsup:
  16. Jun 14, 2011 at 5:43 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  17. Jun 14, 2011 at 5:47 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    I got 295/70/17's with Fox 2.5 CO's and I never rub, but I also have an All Pro bumper which gives me much needed clearance up front . Maybe u need more lift up front or look in to an aftermarket bumper?
  18. Jun 14, 2011 at 6:21 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    if you has less back spacing it would rub less on the frame. the the more a tire sticks out due to higher offset when you turn your wheel it hits the frame more at full lock.
  19. Jun 14, 2011 at 6:25 PM
    BajaTaco
    Huntersville, NC
    Thanks guys.
    I'll look into a higher lift and/or coil-overs for the front or else just get used to the rubbing. In the meantime, the body mount will not be damaged by minor rubbing, it's solid! I appreciate everyones' input.
    BajaTaco
  20. Jun 14, 2011 at 6:32 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    ^ X2 -- it's just plastic...it'll grow back!! :D
