285/70-17 Spare Tire Mod for 2013 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uncleART, Jun 30, 2013.
  1. Dec 4, 2013 at 12:32 PM
    uncleART
    uncleART [OP] Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    Bummer! I read your post in another thread. Yeah maybe your axel is back a little + some extra tread. That sucks. Well under the bed is convenient, but probably the worst place to put it, for wheelin.
    What you need is a high clearance rear bumper with a spare tire mount :)
  2. Dec 4, 2013 at 12:49 PM
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    That's my next mod coming up :)
    Just money now...
    & I'm worried ill lose functionality of my backup camera.. Hmm
  3. Dec 27, 2013 at 2:12 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    So I hammered the shit out of the tabs and stuffed my 33" spare up in there but It's still rubbing on the diff when i'm flexing the rear. What would you guys do about this issue? I've been wheeling with it a couple times and I can see the rub marks on the differential. I haven't messed with the exhaust hangers or anything yet.
  4. Dec 27, 2013 at 4:22 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Could be that your tire is a little over 33" and/or your axle is back a little. What do you have for leaf springs? I think my Duratracs are actually 32.8"; and I have very little clearance to the diff. But I don't rub. Is your spare tight against the hitch receiver?
  5. Dec 29, 2013 at 3:53 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    My spare is 32.7" and has about 2" away from the hitch. I have the Icon 3 leaf progressive pack. How would I pull the spare up closer to the hitch? When I raise it up it just leaves 1/2" clearance on the diff and rubs when wheeling.
  6. Dec 29, 2013 at 3:56 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    I rub very lightly on the rear diff...this isn't a big deal right? I just don't know how to position the spare closer to the hitch receiver.
  7. Dec 29, 2013 at 3:57 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    If I'm parked facing downhill or level I have to pull the spare back towards the hitch when I raise it. If I'm parked facing uphill it just naturally ends up against the hitch
  8. Dec 29, 2013 at 3:58 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    You need to get the spare hard up against the hitch receiver. You may have bent your locating tabs forward too much. My spare is wedged between the hitch and those tabs. The tabs prevent the tire from going forward into the diff.
  9. Dec 31, 2013 at 9:49 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Ok I'll try getting the spare up against the hitch. I am gonna play with the tabs to see if I can position it closer to the hitch.
  10. Dec 31, 2013 at 11:02 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Yeah I only have like 1/2" of clearance to my diff, but never makes contact.
  11. Jan 1, 2014 at 2:29 PM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    I originally tried to get the spare up against the hitch but I was on level ground. Hopefully parked on my driveway I can position it up against the hitch.
  12. Mar 9, 2015 at 5:56 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Is there a problem with it occasionally touching the rear diff? With my after market rear bumper/exhaust, I was planning on putting my 35" spare there aired down to like 5 psi (I have OBA). My 33" tire fits with plenty of room. It would just be there for when I travel accross the country and need maximum bed space. It goes into the bed when I wheel. My thinking is if it touches the rear diff and it is aired down enough it wont matter if I hit a bump in the road.
  13. Mar 16, 2015 at 7:50 AM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    I would think a 35" would hit most of the time under there, even aired down. I only have about 1/2" clearance on my 33. I wouldn't recommend storing a 35 under the bed and having it interfere with the rear axel.
  14. Jul 12, 2015 at 7:31 AM
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
    can the stock 17 inch spare rim that came on the Sport model accommodate a 285/70/17 spare tire? if not, what rims do you recommended?
  15. Jul 12, 2015 at 8:49 PM
    #35
    Jareds Toyota
    Jareds Toyota Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    looks like he used his spare rim
  16. Jul 12, 2015 at 9:40 PM
    #36
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    It depends on your tire. Check the mfgr's website. They will show specs for the narrowest rim your tire should be mounted on. I think the Sport spare rim is 7" or 7.5" wide. Some 285's will mount on that narrow a rim, and others won't.
  17. Jul 12, 2015 at 10:10 PM
    #37
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    This should be a sticky
  18. Jul 12, 2015 at 10:45 PM
    #38
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    Pretty sure its a 7.5 inch wide wheel. Which is fine for a 285
  19. Jul 13, 2015 at 1:34 PM
    #39
    acrossawire
    Fresno, CA
    2010 DCSB 4x4 Sport
    thanks gang- my 2010 came with a 17x7.5 spare rim, BFG's site says 285/70/17's will fit. Follow up question: do the stock rims have enough backspacing to clear a 2.5in lift up front? I believe my XD's have 4.5in.
  20. Jul 21, 2015 at 8:56 AM
    #40
    MotoMoose68
    MotoMoose68 Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    I would recommend some exhaust wrap near the spare. I was pulling a big trailer with my Z-71, one time and saw what looked like a dragging chain when looking in the mirrors, while driving. Stopped to check it, and it was molten burning rubber from my spare being too close to the exhaust. I was wondering why nobody would tail gate me that night.
