285/70/17
Discussion in 'Wheels & Tires' started by Rhinotaco21, Jan 6, 2013.
  1. Jan 6, 2013 at 5:15 PM
    Rhinotaco21
    Rhinotaco21 [OP] New Member
    05 tacoma sr5
    3in rev tec lift, dual flow master, aem cold air intake, window tint
    Can I put 285/70//17 on my 05 Tacoma? I have a 3in rev tec lift.i was wondering if I had to trim the finders? Or will they fit just fine with the 3in lift?
  2. Jan 6, 2013 at 5:18 PM
    Bpfaff45
    Bpfaff45 Well-Known Member
    Branden
    South Dakota
    06 SR5 TRD off road
    They will fit. No trim is necessary. With a 3in lift you could toss 33's under there
  3. Jan 6, 2013 at 6:44 PM
    Rhinotaco21
    05 tacoma sr5
    Do you need to trim if you throw 33s on there.
  4. Jan 6, 2013 at 6:48 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    13 TRD OR 4wd, 6spd
    this and that...
    the consensus i keep running into is that you need to modify to accomodate those tires. some is real minor and some is pretty drastic. been reading up on this topic, cause i want to run those tires on my 13 but not at the expense of cutting anything. i guess its 275 70 17 for me.
  5. Jan 6, 2013 at 8:35 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not true, unless you never flex the suspension or turn the wheels to full lock.
    OP, you'll also need wheel spacers to clear those from the UCAs if you have stock wheels.
