285/70/17?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickH92, Mar 5, 2013.
  1. Mar 5, 2013 at 11:44 AM
    NickH92
    NickH92 [OP] Member
    Nick
    Tuscaloosa
    '11 Tacoma Trd Sport Pkg. 4x4
    10% window tint all around. 6000k HID headlights. Blacked out Emblems.
    Thinking of running these. I'm getting 2 1/2" front spacer and 2" rear block. I'm running 265/70/17 stock height. If I go to 285/70/17s will I have to worry about rubbing?
  2. Mar 5, 2013 at 11:53 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Yes you will need to trim if you go off road, maybe not if you don't.
  3. Mar 5, 2013 at 12:03 PM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    You are going to have to trim and do a cab mount chop if you want to off road or at least be able to turn hard.
    It is not really height that is going to be your enemy it is full turn that will be your issue. A lot of people seem to take off their mud flaps to help clear. Plus it all depends on backspacing and off-set of the wheel.
    What you want to do with the truck?
    Cab mount chop: Buy Here
    There are a ton of threads around to get a feel for what it takes.
  4. Mar 5, 2013 at 12:09 PM
    NickH92
    NickH92 [OP] Member
    Nick
    Tuscaloosa
    I'm not going to be doing hardly any off-roading. I'm just going for better look for the truck is all.
  5. Mar 5, 2013 at 4:19 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    You'll still have to do some trimming since those tires are so wide. I am running 3" of lift and 255/85R16's and I managed to get away with not having to cab mount but I had to trim up the fender flares and back of front bumper quite a bit just for street driving.
  6. Mar 5, 2013 at 9:12 PM
    4Wheelin4Banger
    Randy
    What's the BS on your wheels? 16"x8"s?
    With my 3" OME lift my 255/85/16 BFG KM2s on 1st Gen TRDs (16"x7" with 4.5" BS) don't rub (except twice a slight rub on the bump on the mud flap inside the wheel well if I bounce the front end real hard at full lock). No trimming & still running mud flaps.
