285/70/17's - Let see them
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CMW_TRD_Sport, Aug 18, 2017.
  1. Jul 31, 2018 at 8:09 AM
    #141
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did they redesign the duratracs? These remind me a lot of the MTRs
    Truck is looking good:thumbsup:
  2. Jul 31, 2018 at 8:18 AM
    #142
    brentox
    brentox Active Member
    Crestwood,KY
    2015 Tacoma TRD ORCC/SB
    Bilstein 5100s w/TOYTEC 3" Front, 5160s Rear, CAMBURG UCAs, 1" TOYTEC Body Lift, CMC, 285/70/17 MTRs on Fuel Wheels (17x9 +1 offset)
    I dont know about a redesign, but you are correct these are the duratrac MTRs i should have specified. Thanks man!
  3. Jul 31, 2018 at 8:23 AM
    #143
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Rci metalworks, they are awesome!!!
    2370[QUOTED] likes this.
  4. Jul 31, 2018 at 8:23 AM
    #144
    BassAckwards
    Gotcha! I didn't know they called the MTRs duratracs as well. I thought it was only the all terrain version. You learn something everyday :thumbsup:
    brentox[QUOTED] likes this.
  5. Jul 31, 2018 at 8:37 AM
    #145
    brentox
    Crestwood,KY
    You know i may have misspoke and just called them Duratracs out of habit. They are actually MTRs w/ Kevlar but no mention of Duratracs. I learned something new today! Well played sir.
  6. Oct 13, 2018 at 7:39 AM
    #146
    sblspawn
    sblspawn Well-Known Member
    How are the Corsa tires holding up?
  7. Oct 24, 2018 at 12:43 PM
    #147
    Jeremy4x4
    Jeremy4x4 Zero frucks given
    2017 sr5 4x4 double cab
    3by2 level kit 285 70 17 nitto tires,
    Any rubbing
  8. Oct 25, 2018 at 10:01 AM
    #148
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    narrower width maybe....
    fwiw... those who are looking to run mud terrains full time.... my cooper stt pros are way louder than I ever thought they could be.... they are also very heavy... i am running 265/70-17s and my mpg took a hit, couldn't imagine 285/70-17s.... i'd definitely consider a regear if going that route....
  9. Feb 11, 2019 at 8:56 PM
    #149
    HunterLemon228
    HunterLemon228 Member
    Hunter
    2018 Cement Tacoma Off-Road
    What lift are you running? Thinking of grabbing these wheels and a set of Toyo MTs this week! Truck looks great
  10. Feb 11, 2019 at 9:11 PM
    #150
    Ian679
    Ian679 New Member
    Ian
    Trinidad, Tx
    2010 Tacoma TRD sport long bed
    3inch OME lift with AAL Road Armor front guard Aux beam light bars Weather tech floor mats
    3inch OME with rear AAL.
    SPC UCA
    No spacers.
    No rubbing no cutting
    Avg 14.5mpg
    Could get 16 if I cared enough
    Boonie Buster likes this.
  11. Feb 12, 2019 at 8:13 AM
    #151
    Marceleg9
    Marceleg9 Member
    Los Angeles
    2011 Tacoma TRD Offroad 4x4
    Thanks man! At that time a 3" spacer lift in the front and a 1" add a leaf in the rear. Do it!
  12. Feb 12, 2019 at 8:16 AM
    #152
    HunterLemon228
    Hunter
    Thinking of going with Bilsteins and OME coils, but what spacer lift were you running?
  13. Feb 15, 2019 at 5:51 PM
    #153
    Marceleg9
    Marceleg9 Member
    Los Angeles
    Procomp
  14. Feb 25, 2019 at 2:26 AM
    #154
    Daltong
    Daltong Well-Known Member
    Dalton
    Tempe, AZ
    19' Cement DCSB TRD Off-Road 4x4
    Old truck,
    Wheels: Black Rhino 17x9
    Tires: Cooper Discover ATP LT 285/70/17
    Will post new truck when lift gets installed on tuesday.
  15. May 15, 2019 at 8:17 PM
    #155
    Zander3000
    Zander3000 Member
    Zander
    2020 voodoo tacoma trd offroad
    Sso slimline winch bumper- Slim single light bar- Dobinson 2.5” lift- Method wheels 285/75/r16 Mt’s- Tpam with ram mount- Tan soft topper- 42” toolbox- Singcase-
    285 70 17 fallen wildpeak A/T
    2.5” front spacer
    1” rear block
    Rubs a little on aftermarket fender flare. Trimming it up this weekend.
  16. May 15, 2019 at 8:23 PM
    #156
    Thetacotruck71
    Thetacotruck71 Well-Known Member
    James
    2019 TRD Off Road
    KO2s
    4 inch lift
    geoyota760 likes this.
  17. May 15, 2019 at 8:34 PM
    #157
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
    OME, 886'S Front
    OME, Dakars Rear
    Nitto Ridge Grapplers- 285/70-17
  18. May 16, 2019 at 7:08 AM
    #158
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    285/70/17 copper at3 xlt’s on TRD 4Runner wheels.
    2.5” stage 2 icon lift.
  19. May 16, 2019 at 8:49 AM
    #159
    N2wrenchin
    N2wrenchin Member
    Joe
    2009 Tacoma
    TC/King coilover lift, rims and tires
  20. May 16, 2019 at 9:21 AM
    #160
    Jess-YODA-coma
    Jess-YODA-coma Active Member
    Jesse
    2010 double cab TRD SR5-Grey- Running 33's
    2010 double cab-grey, light bars, 3 inch lift, 33x12.x17. RDR wheels
    N2wrenchin What rims and tires are those? I really like that look. I'm currently running 33x12.5x17 and looking to go to a setup like yours? I like the stance. Is that all backspacing? spacers? I assume the poke out a little?
    Ah, After zooming in i see they are BFG Ko2's, I am surprised. they usually look so square. I like how your are bubbled out a little. Those rims might look good on my Metallic grey coma. Nice truck man!!
