285/75/16 Nitto TG's + Stock TRD 16" Rims + Stock UCA's + 3" lift = ???
Discussion in 'Wheels & Tires' started by TacoCo, Feb 27, 2009.
  1. Feb 27, 2009 at 1:17 PM
    TacoCo
    TacoCo [OP] Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Just curious if anyone has the above setup on a 2nd gen, 285/75/16 Nitto Terra Grapplers on stock 16" TRD Off Road Rims with a 3" lift and stock UCA's, and if so, do the tires rub on the UCA's? I'm trying to figure out if I'll need to run spidertrax spacers for this setup, and I didn't have much luck using the search feature.
    Thanks!
  2. Feb 27, 2009 at 1:19 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    if ur goin 3 inches, then its a good idea to get ucas
  3. Feb 27, 2009 at 1:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep. They will rubb. You will need to get some Camburg or Total Chaos UCA's to avoid the rubbing, if you dont want to use wheel spacers.
  4. Feb 27, 2009 at 1:29 PM
    TacoCo
    Colorado
    Unfortunately, I don't think I'll be able to convince the wife that I need $600 UCA's so that the bigger tires that I just put on because I bought the lift won't rub. She's not going to be all too happy about that, so I guess I'll have to pick up some Spidertrax.
