285/75/16 or 32-11.5-15
Discussion in 'Wheels & Tires' started by malander, May 6, 2011.
  1. May 6, 2011 at 8:44 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    As with most things on my truck I've come to a point that I think is worthy of debate. I will be getting new rims and tires when my rear lift is done and paid for and I have two options.
    1. 3rd gen 4runner rims and 285/75/16 "warden a/ts" (basically treadwrights version o the bfg)
    2. 15x8 granite alloy ga9s (or similar) and 32-11.5-15 bfg a/ts
    I'm not looking for a massive tire just something that'll give me a little more clearance and traction.
    The obvious benefit to the 285s is that they would be cheaper, as well a some used 4runner rims.
    I don't know if I need that tall of a tire though, and if I did I'd like to upgrade to a standard size tire, such as a 33-10.5 or possibly 33-12.5.
    That set up will probably be around ~700-800
    The granite alloys or other 15" rim are sure to be a bit more expensive, and treadwright doesn't carry 32"s so I'd be left to buy brand new tires which would also drive the price up.
    That set up will probably cost ~1000-1200
    I need some help deciding. Anyone have a good middle ground for me? I've also been looking at wheels and can't decide what I would want in an aftermarket rim. I like the beadlock look even if it is a bit poserish, and I like the ga9s because of the bead ring, only problem with those is that they have 3.75" backspacing and I'd like to keep it to 4"
  2. May 7, 2011 at 9:55 PM
    malander
    max
    01 limited trd 4x4
    Bumpity I know y'all have opinions
  3. May 7, 2011 at 10:04 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I say 285/75/16s. I'm about to get the treadwright warden a/ts too. 33/10.5/15s or 255/85/16s would be what I would get if the treadwrights weren't such a good deal.
  4. May 7, 2011 at 10:08 PM
    malander
    max
    01 limited trd 4x4
    I wish the 5 star rims came in 15". I'd be all over that and get some 33-10.5s. It would also be pretty cool to paint them gunmetal grey
