285/75/16's and 5100's
Discussion in 'Wheels & Tires' started by MyTaco, Aug 17, 2008.
  1. Aug 17, 2008 at 3:48 PM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    On the 2.5 height can I get away with running 285's without any robbing with stock wheels?
  2. Aug 17, 2008 at 3:54 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I am going to stick my head in here and say no, they will not fit on stock wheels I know they would not work on my 16" TRD wheels.
  3. Aug 17, 2008 at 3:55 PM
    longbow
    Bill
    Indiana
    forgot to add this, yes you will rub. I had to remove my front mud flaps, and if I crank the wheel hard I rub a little in the front. A real easy fix but to lazy to do anything with it.
  4. Aug 17, 2008 at 3:59 PM
    MyTaco
    Az
    08 Prerunner
    Thanks, may just go with 275's instead.
  5. Aug 17, 2008 at 4:19 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    You can't run 285/75 on stock wheels unless you run spacers (otherwise you'll rub the UCAs) and you will still have to do trimming on the fender plastic and mud flaps.
  6. Aug 17, 2008 at 4:21 PM
    MyTaco
    Az
    08 Prerunner
    275's clear w/o spacers?
  7. Aug 17, 2008 at 11:10 PM
    MooseTX82
    MooseTX82 Moose
    San Diego
    08 TRD Sport 4x4
    Airaid Intake, Magnaflow Exh System, Icon Front Coilovers, TC UCAs, BFG 285s on 17" MotoMetal 951s, ARB Bumper, Hella Running Lights, Alpine CD HU, 6.5 Front JL Audio, 1 10" Kicker powered by Alpine 4 channel Amp
    You WILL rub. I installed my 285s last week on 17s and I rubbed on the 2.5 preset. Cranked on the coilovers till i got more clearance.
