285/75/r16 tires with 2.5" OME lift & wheel spacers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by toutenhoofd, Oct 13, 2012.
  1. Oct 13, 2012 at 8:28 PM
    toutenhoofd
    toutenhoofd [OP] Well-Known Member
    Nico
    Boulder, Colorado
    01 TRD Off-Road DC
    2.5" OME lift. 33" tires, sliders, ARB compressor, home-grown roof-top-tent.
    I'm running 33" tires (285/75/R16) with a 2.5" OME suspension lift and I'm considering putting on some .75" wheel spacers. I'm not doing this for aesthetics -- I'm trying to eliminate the very slight rubbing I get on my frame from the big tires when the wheel is cranked all the way to one side. These are the thinnest hub-centric spacers I could find.
    I'm wondering if running the spacers will just change my rubbing problems and shift them from the frame to the fender wells.
    Does anyone out there run 33" tires with a 2.5" OME suspension lift and wheel spacers?
    I haven't done the pinch weld mod, but I obviously could do that pretty easily.
    Thanks.
  2. Oct 13, 2012 at 8:48 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    Don't mean to hi-jack but 285/75/16r are they 33" tall ? Just curious thats what i got. I haven't even measured mine. I am thinking going down 31/10.50/15
  3. Oct 13, 2012 at 8:52 PM
    toutenhoofd
    Nico
    Boulder, Colorado
    01 TRD Off-Road DC
    32.8" according to this calculator:
    http://www.miata.net/garage/tirecalc.html
    Cheers
  4. Oct 13, 2012 at 8:52 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    285/75r16 = 32.8"
  5. Oct 13, 2012 at 8:54 PM
    toutenhoofd
    Nico
    Boulder, Colorado
    01 TRD Off-Road DC
    I must have beaten you to the submit button by a second or two :)
  6. Oct 13, 2012 at 8:55 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Haha yep. OP-do your tires rub on the upper control arms at full lock? This is the main reason people run spacers on stock wheels with 285s
  7. Oct 13, 2012 at 9:04 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    And youre on the right track, spacers should stop the rubbing on the frame but will most likely increase the rubbing in the wheel well and possibly cause rubbing on the cab mount
  8. Oct 13, 2012 at 9:43 PM
    Sittingbull2
    Mitch
    Southeast texas
    Evanmb31, I know your asking OP but on mine I don't have a rubbing problem at all I have some 16" Eagle Alloys aftermarket rims that were for a 2000 Chevy Z71 it also has a 3" body lift came with the truck when i bought it.
  9. Oct 14, 2012 at 8:52 AM
    toutenhoofd
    Nico
    Boulder, Colorado
    01 TRD Off-Road DC
    Here's a photo of the rubbing. I think this is on the control arm.
    It's really hard for me to guesstimate what a 3/4" spacer will do in terms of the fender well clearance, which is why I was hoping that someone else had experience. I might just go for it.
    Thanks
