285/75R16 on 2005 TRD Tacoma?
Discussion in 'Wheels & Tires' started by brettsnowboards, Apr 1, 2012.
  1. Apr 1, 2012 at 9:23 PM
    brettsnowboards
    brettsnowboards [OP] Member
    Knoxville, TN
    05 Tacoma TRD
    I've been looking around, but can't come across a straight answer. I need answers and pictures if possible.
    I've been looking at BFG A/T KOs in 285/75R16 and getting some Bilstein 5100 shocks and adjustable struts to boost my nose up 1.5"-2". And I do have the stock TRD 16" wheels and have no plans to change (I do love them)
    I want the wheel wells to have that stuffed look. I've never been a fan of a lot of open wheel well space.
    This is my daily driver and will ever see extremely minor off highway use.
    Much thanks.
  2. Apr 1, 2012 at 9:25 PM
    brettsnowboards
    Knoxville, TN
    05 Tacoma TRD
    That is what I am talking about lol of course I'm not sure if there is much of a difference between the 05 and 07
  3. Apr 1, 2012 at 9:26 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    Why not just stick with 265/75/16 and set the front at 1.75
  4. Apr 1, 2012 at 9:28 PM
    brettsnowboards
    Knoxville, TN
    05 Tacoma TRD
    That may look just fine. I just have a thing of wanting to see it before I do it. Sucks
    I could also stick that size underneath without raising the nose. So I have a feeling raising it after that (I do want to raise it) will just leave more wheel well.
  5. Apr 1, 2012 at 10:38 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    285/75R16 tires on your wheels will rub the factory upper control arms unless you put on wheel spacers.
    If you really want the "stuffed" look, just go with 265/75R16 on stock wheels, at stock ride height. That's 1" larger than stock.
    No matter what your lift height, 285/75R16 is going to need plastic wheelwell trimming and mudflap removal, as well as possibly cab mount chop.
  6. Apr 2, 2012 at 5:54 AM
    brettsnowboards
    Knoxville, TN
    05 Tacoma TRD
    Well, I've been wanting to get rid of the droopy nose for a bit. I was thinking the extra height from the tire, plus 1" or 1.5" with the Bilsteins would make it about right
  7. Apr 15, 2012 at 5:31 AM
    Mr Souc
    Mr Souc Well-Known Member
    Joel
    Topsham Maine
    2011 Tacoma TRD Off Road
    - TacoME Satoshi - Hella Supertones - TRD front skid plate - TRD CAI - TRD cat-back exhaust - TRD short throw shifter - TRD 6 speed ball knob - Baja Soft 8 16" wheels - 285/75/16 BFG T/A KO2s - Pioneer AVH-P2400BT - OEM roof rack - Thule Aero roof rack - TSB Add-A-Leaf - 1" Level spacer up front - 5100s front & rear - Eibach 620lb coils - Toytec 2" add-a-leaf - Plasti-Dip bumper, badges, & roof
    I'm in same exact boat. Did you decide anything yet?
    I'm getting a front and rear set of 5100s next weekend and I'm doing my research to see what I can slap on there for rubber on the stock TRD rim. I currently and running 275-75-16s and like you, want to fill that wheel well up.
  8. Apr 16, 2012 at 6:16 PM
    brettsnowboards
    Knoxville, TN
    05 Tacoma TRD
    I haven't done anything yet. Still saving up the $$$, but I have decided that with 1.25" spacers all around and the 5100's cranked up 2.5" for the front end, then the tires should clear with minimal if no trimming at all. Plus Bushwacker flares all around.
    Everywhere on the interwebz I look, that seems to be the magic formula. The spacers will clear the UCAs and the lift will help clear the fenders.
    This is what I have decided on:
    Bilstein 5100 all around. Adjusted 2.5" up front:
    http://www.eshocks.com/bil_veh.asp?Model_Index=0Q76&Manf=Bilstein&SubChar=Q
    1.25" Spidertrax wheel spacers:
    http://www.spidertrax.com/Toyota-Hub-Centric-Spacer?sc=2&category=9982
    Bushwacker Pocket Style flares all around
    http://www.svcustoms.com/i-2155264-bushwacker-31925-02-pocket-style-fender-flares-set.html
    BFGoodrich A/T KOs 285/75R16:
    http://www.tirerack.com/tires/tires...AKORWLV2&vehicleSearch=false&fromCompare1=yes
    That's what I'm doing as far as that goes. I have a few other plans as well.
    Please let me know what you decide to go with and how it goes. Always with pictures!!
  9. Apr 25, 2012 at 6:40 PM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    why not just get some wheels with enough backspacing? I just put 285s on my 2011 and I only have to do some minor trimming since it's also my daily driver.
