285/75R16 tires without rubbing?
Discussion in 'Wheels & Tires' started by Teufel Hunden, Nov 17, 2008.
  1. Nov 17, 2008 at 1:03 PM
    Teufel Hunden
    Teufel Hunden [OP] No Better Friend, No Worse Enemy
    Northern Virginia
    09 MGray DC SB TRD-OR 4x4 V6 Auto SR5
    Undercover tonneau, OEM tow package with hitch, OEM retractable roof rack, Front window tint (legal), WeatherTech FloorLiners, Door sill protectors, Tacoma bed mat, Rear leaf spring TSB, OEM DRL mod, Door edge guards, AFE Pro-Dry S Air Filter, Removed secondary air filter, Smoked LED 3rd brake light, Romik running boards, Go Rhino hitch step, Extra set of D-rings mod, Bed cargo net, TRD wheel locks, OBX sport pedal covers.
    I am purchasing a set of FJ wheels, which I believe have a 4.5" backspace, and was wondering if a 285/75R16 tire will fit without any rubbing issues. I do not have a lift installed, the only thing I have done is the rear leaf TSB. The rest is all stock. My truck is only two months old, so I am still saving up for a lift. I have the TRD Off-Road Package, which has alloy wheels and 265/70R16 tires. Any help would be greatly appreciated. Thanks!
  2. Nov 17, 2008 at 1:10 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    285s won't fit without a lift. You might be able to do some MAJOR trimming (maybe even the cab mount), but I think you'll need a lift to fit 285s.
  3. Nov 17, 2008 at 1:12 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    ur gonna have to get rid of the mud flaps too
  4. Nov 17, 2008 at 1:15 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yep, need 3" lift or maybe the mudflaps removed and some major trimming like the other guys have said. a 265 would probably fit though.
  5. Nov 17, 2008 at 5:32 PM
    Teufel Hunden
    Northern Virginia
    Thank you to everyone for your advice, I really appreciate it. I will stick with the 265 tires until I get a lift.
  6. Nov 27, 2008 at 10:08 PM
    HighPlains
    HighPlains Well-Known Member
    Do you think that tire size will fit if one stays with the stock TRD Off Road Wheels?
  7. Nov 27, 2008 at 10:15 PM
    LonghornTaco
    Minnesota
    Really don't think so. I think you're in the same boat with no lift and 285s regardless of backspacing...
  8. Nov 28, 2008 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Even if lifted, 285's on the stock wheels are gonna rub the Upper Control Arms when turning.
  9. Dec 1, 2008 at 11:37 AM
    jnj13
    jnj13 New Member
    MS
    tacoma 4x4
    If you put a leveling kit on it and 1/8 in spacers it will allow you to run the 285s... but the mud flaps on the front will have to be removed
