285/75r16
Discussion in '1st Gen. Tacomas (1995-2004)' started by First Gen 98, May 19, 2016.
  1. Dec 15, 2016 at 9:07 PM
    #61
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I thought of running 285's as well. But after getting back from Moab in October, I reversed my thinking. I was able to do far more than I thought my truck was capable of with 3" lift, sliders, and 265's. Ran some pretty difficult trails with smart spotting. Larger tires would not have made a great bit of difference fo me. My biggest issue was my rear receiver hitch. I'm not to sure the minor trouble of fitting 285's is worth it for me. But they do look good...
    PROseur likes this.
  2. Dec 22, 2016 at 1:42 PM
    #62
    First Gen 98
    First Gen 98 [OP] 2 Strokes Rule!!
    Nick
    Bostic, NC
    1998 Taco ext cab 3.4 5sp manual hubs 4x4
    Rough country leveling kit
    I haven't went 285's yet because I'm still wearing my 31's out, but when I do I will prob be going with a heavy M/T, I have a 3.4 4x4 5 speed ext can with 3.91 gearing, do y'all think that gearing will be able to pull the heavy and tall 285's?
  3. Dec 22, 2016 at 2:05 PM
    #63
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I had probably one of the heaviest out there, Toyo MT's. Lost some power but no real issue. I only noticed the power less after I went to bigger wheels and tires.
    Plus, mines an auto so yours should take it even better
  4. Dec 22, 2016 at 2:10 PM
    #64
    First Gen 98
    Nick
    Bostic, NC
    Yeah I honestly am kind of welcoming the taller it's gonna make 2nd and 3rd, I think there to short unless your hauling heavy lol
  5. Dec 22, 2016 at 2:19 PM
    #65
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    3.91 gears? That's gonna suuuuuck with 285s. Especially if you have armor or haul a lot of crap around. I would go 4.56 minimum gear ratio, or supercharge it.
    DustStorm4x4 and FirstGen Jer like this.
  6. Dec 22, 2016 at 2:25 PM
    #66
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I think 4.56 is overkill for 285s... I have 4.10s but I don't think it'd be that big a difference
  7. Dec 22, 2016 at 2:26 PM
    #67
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Gonna be real sluggish off the line forsure. Would be worse if you had a auto. I have 4.10's with a v6 5 speed, could not imagine having any lower gearing and being somewhat content. I would recommend not going anymore then a 265 unless you re-gear. With your gear ratio your rpm's at highway speeds will be high
  8. Dec 22, 2016 at 2:28 PM
    #68
    FirstGen Jer
    Jeromey
    4.56 puts it back closer to stock with 285's. I have 4.10's also and if you wheel your rig it sucks. Around town it's not a big deal just a little less pep off the line for me.
  9. Dec 22, 2016 at 2:38 PM
    #69
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    My trucks only been in sand and mud but its done well for that. I guess rocks and all you need more torque
  10. Dec 22, 2016 at 2:54 PM
    #70
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah definitely terrain-dependent. Also if you're up in the mountains. I had 4.56 with 33s and it was barely adequate where I'm at. Now I have 35s and it sucks.
  11. Dec 22, 2016 at 2:59 PM
    #71
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I'd die if I had to deal with any hills lol
  12. Dec 22, 2016 at 3:07 PM
    #72
    FirstGen Jer
    Jeromey
    Your 12.5" wide's too right?
  13. Dec 22, 2016 at 3:10 PM
    #73
    FirstGen Jer
    Jeromey
    5.29's. :D :burnrubber:
  14. Dec 22, 2016 at 3:25 PM
    #74
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Yessir
    FirstGen Jer[QUOTED] likes this.
  15. Dec 22, 2016 at 3:33 PM
    #75
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yep, that's what's going in the solid axle.
  16. Dec 22, 2016 at 3:48 PM
    #76
    First Gen 98
    Nick
    Bostic, NC
    Yeah 4:56 would be what I would go with, but if I end up regearing I want to also ARB lock it so it's just more and more money lol and I don't necessarily wheel, just old hunting trails and occasional snow if I'm lucky, and rarely haul anything heavy besides my bikes
    DustStorm4x4 likes this.
  17. Jan 31, 2021 at 5:40 PM
    #77
    520Tacotime!
    520Tacotime! Member
    2001 Tacoma TRD
    2.5 leveling kit
    How big was the power difference when you went 285s?
  18. Jan 31, 2021 at 5:44 PM
    #78
    520Tacotime!
    520Tacotime! Member
    2001 Tacoma TRD
    2.5 leveling kit
    How is the power difference when you went 285s?
  19. Jan 31, 2021 at 5:49 PM
    #79
    razhick4x4
    razhick4x4 Well-Known Member
    Alex
    MT/WY
    2004, Tacoma SR5 Xtracab TRD, 4x4, Red, 5spd. V6
    ARB Bumper, 3" Toytec/OME lift, 33s, Sliders, ARE Topper, Ditch Lights, Hella LEDs, Trigger controller, CB, Pioneer Radio
    it's noticeable but not awful. the V6 handles it well in the city but highway leaves a bit to be desired. especially out here in MT with mountain passes and high elevation. i'm debating whether to regear or to try a set of 255s first. i think that either way i'll go to 4.56 gears tho.
    welcome to TW btw!:wave:
  20. Jan 31, 2021 at 5:57 PM
    #80
    520Tacotime!
    520Tacotime! Member
    2001 Tacoma TRD
    2.5 leveling kit
    Thanks for the welcoming
    I’m in between 265/75/16 or 285/75/16
    I really want the 33s but I don’t want to sacrifice my power and don’t want to regear
    Just yet.
