285s or 265s
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2k4Taco, Nov 28, 2012.
  1. Nov 28, 2012 at 5:36 PM
    2k4Taco
    2k4Taco [OP] IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Hey guys Im looking at buying new tires and I cant descide whether I want to go with 285 75 16s or 265 75 16s. Im running 5100/stock coils in the front and stock in the rear.I will be installing eibachs and Wheelers 3 leaf aal in the rear. I dont do much off road but when I do its sandy and I stay away from the mud. MPG isnt a hugh deal breaker for me, Im just worried about rubbing and strain on the truck. Im running stock TRD wheels so theres not much off set. Thanks for your help guys!-Swanny
  2. Nov 28, 2012 at 5:48 PM
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    ive got 285/70/17... they effect my mph. quite heavily. so therefore i drive 50-55mph every where i go i can get about 100 miles per quarter tank.
    but i have 2.5 inch lift. and trimming done and they still rub if i turn hard
    anyway hope that helps
  3. Nov 28, 2012 at 9:35 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    With Eibachs you will probably be just fine. You'll need some wheel spacers, Spidertrax, All-Pro, etc. so that your tires don't rub the control arms and/or frame.
    You may have to do the pinch weld mod. Do a search this is a topic that has been covered many, many, many times.
    Also check out the eibach/billy thread, there are several guys running 285s with that set-up.
  4. Nov 28, 2012 at 9:39 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    If your worried about rubbing go with the 265/75/16.
  5. Nov 29, 2012 at 11:23 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    255/85-16 for the win!!!! i have the km2s on my truck in this size and they are absolutely awesome!!!!
  6. Nov 29, 2012 at 11:29 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  7. Nov 29, 2012 at 11:34 AM
    mgiguere20
    mgiguere20 Well-Known Member
    Worcester, MA
    10 TRD Sport DCLB
    5100's, K&N intake, grillecraft grill, complete stereo
    I'd go 265, looks good on a truck with 3" or less lift and a lot less rubbing!
  8. Nov 29, 2012 at 1:47 PM
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    What do you have for suspension?
  9. Nov 29, 2012 at 5:03 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    3.5 in the front on ome s and 4 in their with an add a leaf and lift shackles with procomp exteended shocks
