295/70/17 PSI?
Discussion in 'Wheels & Tires' started by Steve33fish, Oct 22, 2012.
  1. Oct 22, 2012 at 1:49 AM
    Steve33fish
    Steve33fish [OP] Well-Known Member
    Yorba Linda
    13 Tacoma 4x4 LB
    Hey guys just put these tankers on the yoto. 295/70/17 Their rated for 80 psi! How much psi should i run? currently running about 60 psi. I have had them on for about two weeks and it seems ok, but today on the freeway with my full set of family (5 people) around 75 mph the ride was a little uncomfortable. [​IMG]
  2. Oct 22, 2012 at 9:06 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  3. Oct 22, 2012 at 10:43 AM
    Steve33fish
    Yorba Linda
    13 Tacoma 4x4 LB
    Man, I guess 60 psi is to high???
  4. Oct 22, 2012 at 10:52 AM
    TexasTacoma37
    Way, way too high.
    I've never heard of anyone running over about 38 in our trucks. Factory recommendation is somewhere in the low 30's. check the door jamb sticker.
  5. Oct 22, 2012 at 11:18 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Probably only around 35.
    Just because they're E rated for use on 1 tons with high pressure doesn't mean it's best to run them at that pressure.
    Like kpt said, do a chalk test on em
  6. Oct 22, 2012 at 9:30 PM
    Steve33fish
    Yorba Linda
    13 Tacoma 4x4 LB
    Even if the tire is rated for 80 psi i want to run half? I will lower it in the morning thanks guys!!!
  7. Oct 23, 2012 at 12:58 AM
    RelentlessFab
    Eric
    Sparks, NV
    Yes. consider the load capacity for a single one of the tires you intstalled... 3970lbs direct from the Toyo Website. nearly the entire weight of the truck.
    They're really aimed at being installed on leveled 1ton work trucks in that load range E.
