2GR-FKS Engine Problem/Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ColoradoTJ, Aug 11, 2022.
  1. Mar 4, 2025 at 7:09 AM
    #121
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
  2. Mar 12, 2025 at 4:47 PM
    #122
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  3. Apr 2, 2025 at 8:56 AM
    #123
    Superdave1.0
    SoCal
  4. Apr 2, 2025 at 8:57 AM
    #124
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
  5. Apr 15, 2025 at 5:07 PM
    #125
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
  6. Jun 26, 2025 at 1:52 PM
    #126
    Screws Loose
    Screws Loose New Member
    2018 DCSB TRDOR
    Mileage that problem/failure happened: 111,000
    What actually happened: 2018 SR5 - engine was knocking/tapping for ~2,000 miles before it went in to limp mode while driving. Misfire codes as well as P11EC were prevalent. Dealer identified the vacuum pump as the cause of the tapping/knocking and replaced it. The noise was persistent after vacuum pump replacement yet the dealer said everything was normal. The truck sprung two significant oil leaks - one at the fuel pump gasket and one at the back of the engine by the firewall. The truck also started burning oil. Between the leak and the burn, the engine was losing about 0.75 quarts every 500 miles. I took the truck to another shop where they found compression was low and the engine was out of tolerance on a leak down test. Metal shavings were found in the oil filter and filter housing. Replacement engine was mostly covered under third party extended warranty. Likely cause of failure was related to valve issues but not confirmed.
    Vehicle usage (towing/off-roading/pavement pounder): truck was purchased 6 months ago, history unknown
    Vehicle modifications (tune/geared/tires): N/A
    CygnusX191 and Superdave1.0 like this.
  7. Jul 3, 2025 at 8:42 PM
    #127
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    What did knocking/tapping sounded like? If you have any recordings of it.
    There is this always " is it the bad knock or normal?" question with Tacomas, and it seems like no one knows which is bad and which is normal.
    CygnusX191 likes this.
  8. Jul 5, 2025 at 9:32 AM
    #128
    Screws Loose
    2018 DCSB TRDOR
    That’s a good question. I will upload a video I took before the new motor was put in to YouTube and update my original post.
    CygnusX191 and Tacosauro[QUOTED] like this.
