2inch rear lift
Discussion in 'Suspension' started by brutalguyracing, Dec 14, 2009.
  1. Dec 14, 2009 at 8:35 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    how do you guys feel about 2" block spacers on the rear leafs????
  2. Dec 14, 2009 at 8:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Get an AAL...Blocks are the suck.
  3. Dec 14, 2009 at 10:59 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    blocks are bad. mmmkay.
  4. Dec 14, 2009 at 1:04 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    yeah blocks are really bad, they cause premature dearching of your springs, go with an aal.
  5. Dec 14, 2009 at 1:06 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    AAL > Blocks
  6. Dec 14, 2009 at 1:32 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    ^^ he's got it!
  7. Dec 14, 2009 at 2:06 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    do i need new u bolts with ^^^aal kit???
  8. Dec 14, 2009 at 2:19 PM
    Jigzor
    Pennsylvania
  9. Dec 14, 2009 at 4:01 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    and i assume u need the longer bolts then??? so like $120 total
    im going to see the local spring guy and see about adding 2 extra leaves
  10. Dec 15, 2009 at 10:53 AM
    Toytec Lifts
    Rocky Mountains
    NO no, you do not need longer you bolts if you are doing the AAL with no shims. ONLY if you are putting the shims in with the AAL, are you in need of new U-bolts.
  11. Dec 15, 2009 at 11:07 AM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    As long as your U bolts are not rusty you can reuse them. Before you try and take them off i suggest you soak them in a little wd40. It will make it much easier to take them off.
  12. Dec 15, 2009 at 1:01 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks guys just ordered the kit you guys are the best
  13. Dec 30, 2009 at 5:16 PM
    CNLimit
    CNLimit Member
    Puerto Rico
    Black 06
    The 5100's say they are good for 0-1.5" lifts< will I be ok with the 2" toy tecs?
  14. Dec 30, 2009 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, Its recomended that the U bolts be replaced when adding an extra lift leaf. They are a stressed bolt, and are not intended to be re used.
  15. Dec 30, 2009 at 6:01 PM
    CNLimit
    CNLimit Member
    Puerto Rico
    Black 06
    Stalker on the forum alert! I wanna get AAL's and as far as I've read toy tec is the place, that been said they have 2" AAL's or TSB 1.5". My Taco is a Non TSB :( and I have a full set of Billies on the way, which one should I get? My mission is to level my Taco, any takers on suggestions?
    Thanks
  16. Dec 30, 2009 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Either AAL will work for ya. It all depends on how much rear lift you need to be level.
  17. Dec 30, 2009 at 6:15 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i just got my 2" toytech aal today in the mail planning on putting them on as soon as it stops raining and snowing...are u saying i now need new u bolts...i was told to re use the stock 09 u bolts????
  18. Dec 30, 2009 at 6:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as you have an '09, You may be able to re use them. Im only saying that its recomended they be replaced as, technically, they are not a re usable bolt>
  19. Dec 30, 2009 at 6:19 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I reused mine and haven't had an issue :)
  20. Dec 30, 2009 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And I have done the same on a few other vehicles.
