2JZ into 2001 4X4 Tacoma Build
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2JZ_Tacupra, Sep 18, 2019.
  1. Sep 18, 2019 at 9:01 AM
    tony2018
    tony2018 Well-Known Member
    Hm, I think I'm mistaking the huge space between lines of text as pic insertion.
  2. Sep 18, 2019 at 9:02 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  3. Sep 18, 2019 at 9:07 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Can you elaborate on how you got the body functions to work? Like the A/C, Radio, Instrument Cluster, SRS, Taillights, etc.
  4. Sep 18, 2019 at 9:08 AM
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    i second what BartMaster1234 said
  5. Sep 18, 2019 at 9:11 AM
    2JZ_Tacupra
    2JZ_Tacupra [OP] Active Member
    Antoine
    Houston
    2JZ 4x4 First Gen 5 Speed
    Compound turbo 2JZGTE, Marlin Crawler Dual Case Taco Box, 2010 Superduty 1 Tons
    I see what you are saying. Thanks for the feedback. I'll go back and clean it up.
    Hahaha hoping to get tires and all the coilovers soon.
    Body harness in the Tacoma is conveniently separate from the engine harness. For the sake of saving time and leaving it to the experts I had Tweak'd performance build me the adapter harness so I can retain AC, Instrument Cluster etc via the body plug above the glove box. Cruise control was aftermarket and was just a matter of making a new bracket and cable.
    tony2018[QUOTED] likes this.
  6. Sep 18, 2019 at 9:12 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    So you have a jumper harness that converts the body harness to what, what computer controls that stuff?
    Did you keep SRS? Power doors?
  7. Sep 18, 2019 at 9:26 AM
    2JZ_Tacupra
    Antoine
    Houston
    The main reason I had the harness made was because I imported a JDM 2JZGTE and wanted it to be USDM Spec (EGR, OBDII, MAF, 550cc Injectors all of which JDM doesn't have) with the added convenience of being able to simply plug it in to the main connector above the glove box. Plus they consolidated the R150F transmission connectors in the harness.
    Body harness is unaltered. 4x4 is simple because it is a separate system and doesn't require modification. No other functions were modified so yes airbags, power locks, power windows, etc still work. Those are not a part of the engine harness.
    QMEDJoe and chrslefty like this.
  8. Sep 18, 2019 at 9:29 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    So computer wise, you have the Tacoma ECU controlling it or the Supra ECU controlling it?
    Also, why did you opt to keep EGR? I’d like to do this swap one day but being in California it would have to be emissions compliant.
  9. Sep 18, 2019 at 9:36 AM
    2JZ_Tacupra
    Antoine
    Houston
    Supra ECU.
    To have all the US Emissions equipment.
  10. Sep 18, 2019 at 9:48 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    So you’re using a USDM Supra ECU?
  11. Sep 18, 2019 at 9:54 AM
    2JZ_Tacupra
    Antoine
    Houston
    Yes, OBDII USDM 6 Speed Supra ECU
  12. Sep 18, 2019 at 9:55 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Why do you have to be emissions compliant? Is that why you kept EGR?
    Sorry for all the questions haha
  13. Sep 18, 2019 at 10:25 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  14. Sep 18, 2019 at 10:32 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Sweet Jesus.
    This thing is gonna be a beast!
  15. Sep 18, 2019 at 11:42 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  16. Sep 18, 2019 at 11:50 AM
    #36
    ToyotaHunter
    how much the harness set you back?
  17. Sep 18, 2019 at 6:32 PM
    #37
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  18. Sep 18, 2019 at 7:01 PM
    #38
    yota243
    E.J.
    north Alabama
    Another tx guy... When are some of y'all coming to the heart of Dixie... Asking for a friend
  19. Sep 18, 2019 at 7:10 PM
    #39
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Most casual SAS decision ever. :laugh: :thumbsup:
    DashMaple likes this.
  20. Sep 19, 2019 at 7:12 AM
    #40
    2JZ_Tacupra
    Antoine
    Houston
    IRCC $1200 a while back
    Much appreciated! It helps to have support from the toyota community.
    I may or may not have been searching for an excuse deep down inside. However, given that I was able to produce 316hp/405ftlbs (at the wheels) on a small single and a factory ecu/fueling, snorkel, etc. I was cognizant of the fact that compound turbos would put the toyota axles in the grave. The R150F is pretty stout, but we shall see....
    The EFR 7064 in single would start to build boost at 2k rpm and would achieve 20psi by 3k rpm but would fall off to ~10 psi at 6800rpm redline. The logic behind my decision to go compound is to maintain the amazing low/mid range I had with the single while holding the boost and torque curve all the way to a new 7200-7500rom redline.
