2LM PnP - Plug and play 2WD low range for the 3rd gen. Tacoma
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by lapoltba, Jun 15, 2019.
  1. Feb 23, 2023 at 7:54 AM
    #1861
    lapoltba
    lapoltba [OP] Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Correct, standard on/off, not momentary.
    CygnusX191 and RDT415[QUOTED] like this.
  2. Feb 23, 2023 at 10:24 AM
    #1862
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Who's giving you trouble? I'll fight em..... :D
  3. Feb 24, 2023 at 7:06 PM
    #1863
    lapoltba
    CT - 06076
    California. :bananadead:
  4. Feb 24, 2023 at 7:16 PM
    #1864
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    CygnusX191[QUOTED] and NoOne like this.
  5. Mar 2, 2023 at 10:56 AM
    #1865
    lapoltba
    CT - 06076
    Visor cards will be available again for both MT and AT in the next few weeks (hopefully sooner). I am just waiting for delivery at this point.
    These will still be included at no charge with harness orders, however if you did not receive one, or need a replacement they will be available for purchase. As the original batch of cards were a wonderful contribution from another forum member, I can unfortunately not give away any of the new batch.
    I will make an announcement when they are live on the site.
  6. Mar 2, 2023 at 11:05 AM
    #1866
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Does anyone know if toyota changed the visors by 2021? My 2021 does not seem to have a pocket for the visor card to go in.
    CygnusX191 and tonered like this.
  7. Mar 2, 2023 at 11:10 AM
    #1867
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dammit. That is some good stuff right there. I had no luck trying to gently remove mine. Stickers were not a lot of fun to remove, but they have been gone for a long time. So much nicer.
    CygnusX191 likes this.
  8. Mar 2, 2023 at 11:10 AM
    #1868
    lapoltba
    CT - 06076
    Yes, it was covered a page or two back. Newer trucks do not have a visor pocket.
  9. Mar 2, 2023 at 4:44 PM
    #1869
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Time to start visor modding
  10. Mar 7, 2023 at 6:01 AM
    #1870
    jewboi
    jewboi Well-Known Member
    just ordered. i may have missed it but is there any notification light/LED or dashboard status that indicates when it is engaged? would be nice to have a switch that outputs a little orange LED like some of the other switches... does this exist?
    CygnusX191 and lapoltba[OP] like this.
  11. Mar 7, 2023 at 6:03 AM
    #1871
    lapoltba
    CT - 06076
    Not possible to show actual status on the gayge cluster. It's all over Can bus and not easily accessible.
    Noch and CygnusX191 like this.
  12. Mar 7, 2023 at 6:16 AM
    #1872
    jewboi
    so is a switch with an indication LED possible instead of gauge cluster then?
  13. Mar 7, 2023 at 6:28 AM
    #1873
    lapoltba
    CT - 06076
    That is the default. When the switch is on the top will illuminate. The bottom is always on without tying it into the truck illumination circuit.
    MQQSE and CygnusX191 like this.
  14. Mar 7, 2023 at 6:31 AM
    #1874
    jewboi
    perfect, i didnt realize the recommended switches included that feature! thanks for the reply.
    now i just regret not getting this years ago. my poor clutch from all the slipping in reverse :annoyed:
  15. May 18, 2023 at 9:06 AM
    #1875
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    This MOD is clearly high on the 'best of' list... Thank you @lapoltba ! - I always highly recommend it!
    I'll mention that in addition to the issues addressed in the thread (i.e. Reverse while towing), I find the mod super useful while off road.
    I find myself on some pretty steep and tight winding off-road climbs with ruts, cobbles*, etc. which would necessitate a bit of clutch to negotiate. Being able to slow-crawl and avoid bouncing around over these obstacles is great.
    -It is also it is quite helpful when on the types of steep slopes where the 1st - 2dn gear gap becomes relevant (annoying because you need gear 1-1/2!). Having the ability to use the low gearing changes the ratios more than enough to eliminate this 1st-2nd gear issue very nicely.
    Using the low gear without binding while turning tightly on surfaces that still provide a good amount grip in 2wd makes for very clean climbs avoiding all drama. - No bouncing, slipping, need for engines revving, etc. while looking for momentum. The low gear torque takes care of you instead of the momentum. (Some may find bouncing up a slope entertaining, but when in remote places, you try to avoid breaking stuff...)
    I don't know if others are also using it in this way. I've found it quite useful.
    * Cobble: A class of rock defined on the Udden–Wentworth scale as having a particle size of 64–256 millimeters (2.5–10.1 in), larger than a pebble and smaller than a boulder.
  16. May 18, 2023 at 10:01 AM
    #1876
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I use 4Lo when off road lol
    But Just yesterday I dated to use too low to break my rear drums for you, had a bit of flooding here recently and had to get the truck through some pretty deep water. And like a super smart clown. I did it and drive it the next day because I drove the other one to work and the rear drums were binding up again. 2lo to the rescue
  17. May 20, 2023 at 12:38 PM
    #1877
    Pyrotech
    Pyrotech Well-Known Member
    This is what I use mine for, it is really nice to have the low range of 4low for steep hill descents with sharp turns.
  18. May 30, 2023 at 7:03 AM
    #1878
    lapoltba
    CT - 06076
    2LM visor cards are finally available again. The first batch from the printer were hot garbage so they took their sweet time reprinting them. The new ones look much better.
    All 2LM orders will include a free visor card (must make selection when adding to your cart). They are also available to purchase for anyone that has not received one.
    If you have any issues with the site please let me know.
    mtip, CygnusX191 and daveeasa like this.
  19. Sep 13, 2023 at 9:36 AM
    #1879
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    Looking to purchase two of these kits. One for myself and another for a buddy. When I add two harnesses to my shopping cart the shipping doubles. Is there a way to bypass this?
  20. Sep 13, 2023 at 9:39 AM
    #1880
    lapoltba
    CT - 06076
    My store setup isn't flexible enough to allow for combined shipping. Please PM me your email address and shipping information so I can send you an invoice.
