2lo kit for 2nd gens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Up2NoGood, Jun 17, 2018.
  1. Jul 28, 2018 at 9:21 PM
    #101
    Pigpen
    Dan
    Northwest Montana
    Will this work with my button activated version. You know I'll be trying it before I even get your response. I never thought to try pushing the button while in 4 high.
    I have one of the original modules - hand built by the man himself and no pretty cover. I tow a lot and my truck is heavy. This is the best mod I've done.
    Yellow wire mod. You've been around long enough. You should know this one. :p
  2. Jul 28, 2018 at 9:39 PM
    #102
    Up2NoGood
    Up2NoGood [OP] Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Appreciate the feedback guys! Hope you enjoy the modules
    Yep it will totally work. You can also press it while in 4hi and then set the 4wd selector to 4lo while the confirmation lights are blinking and provided you have the clutch in and under 5 mph etc it will shift you into 2hi to lockout the ADD then into 2lo.
    If you want the new enclosure just say the word... your the reason the product exists! The new enclosures have CNC cut openings for the connectors and the custom graphics on the cover.
  3. Jul 30, 2018 at 9:34 AM
    #103
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    Got my module installed and tested in under 10-mins. The absolute hardest part was getting my body into place without aggrivating my recently broken collar bone. Legitimate plug and play!
    A few weeks till I can get it properly tested on some No Winter Maintenance roads. Very eagerly awaiting the all-clear from the Dr.
  4. Jul 30, 2018 at 9:46 AM
    #104
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    I need to find the funds for this asap!
    Would be huge help with trailering.
    Darkgoatracer likes this.
  5. Jul 30, 2018 at 11:04 AM
    #105
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    I installed my kit a couple or few weeks ago. Did the install while BBQing hot dogs, I can't say how long it took but the hotdogs came out perfect. Since install I use it a lot, hard turns backing up really steep driveways, tight manoeuvres on lawns. It feels like it was always a part of the truck. When I get around to adding a bank of switches, I will probably add one for this module, but it work
  6. Jul 31, 2018 at 6:20 PM
    #106
    hemmjo
    hemmjo Well-Known Member
    Central Ohio
    2005 Access Cab 4wd, TRD, Off Road, Tow Package
    Sounds good. I am very interested. I was just working on getting my post count up to 50 so I can post my 1st gen for sale. Now I have to work on getting it up to 100... lol
    Will the eLocker activate when it is in 2Lo?
  7. Jul 31, 2018 at 6:41 PM
    #107
    hemmjo
    Central Ohio
    Just read some more of the thread, it seems that the eLocker will function in 2Lo. Did I read that right?
  8. Jul 31, 2018 at 6:44 PM
    #108
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Yeah locker will function fine in 2lo just fine. As far as post count no worries on my end. It’s mostly there so a new signup isn’t paying by check.
    DoorDing likes this.
  9. Jul 31, 2018 at 9:35 PM
    #109
    Pigpen
    Dan
    Northwest Montana
    Now that's funny!
  10. Aug 6, 2018 at 11:06 AM
    #110
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Thanks for another well-engineered mod, @Up2NoGood! I'm curious whether the 2lo kit is compatible (i.e., will peacefully co-exist) with the Locker Anytime Mod for Dummies 2005 +?
  11. Aug 12, 2018 at 12:53 PM
    #111
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  12. Aug 12, 2018 at 1:57 PM
    #112
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    PM sent
  13. Aug 13, 2018 at 9:29 AM
    #113
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Hey Guys,
    I’m out of town right now but will try and reply later tonight.
    Norton[QUOTED] and DoorDing like this.
  14. Aug 13, 2018 at 7:33 PM
    #114
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    No worries:thumbsup:
  15. Aug 15, 2018 at 12:54 PM
    #115
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'll take a look into that one. Most likely yes though. Do you know if there is a schematic posted anywhere on that thread of what they have changed. It makes it a bit easier to interpret the mod then just the pictures and description.
    Replied!
    Also Replied!
    Norton[QUOTED] likes this.
  16. Aug 15, 2018 at 2:07 PM
    #116
    Norton
    Thanks! I don't recall seeing any schematics of the change, but will look and forward to you if I locate any.
  17. Aug 28, 2018 at 7:07 PM
    #117
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Any chance you will make a kit for 3rd Gen? I’m guessing you’ll need an experimental loaner truck
  18. Aug 29, 2018 at 6:40 PM
    #118
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Not planning on it. I would absolutely need a 3rd gen to pull it off.... and more free time which I don't have haha. That said @BigWhiteTRD has a DIY for 2lo on 3rd gen's HERE and is also working on a plug and play option for both 2lo and rear diff lock anytime which you can find more details at HERE
    Not sure if he will make it an available kit or not but I suspect if not then he'll probably post a DIY.
    Drainbung and DoorDing like this.
  19. Aug 29, 2018 at 6:42 PM
    #119
    Grossomotto
    2017 4WDV6LB6MT
    Thanks, definitely need this for reverse on the 3rd Gen MT
  20. Aug 29, 2018 at 6:52 PM
    #120
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    I have absolutely no use for this, but I want it.
    Nice job OP. Looks like a quality unit.
    Big Brutus and EdinCincinnati like this.
