2LO Plug & Play Harness Discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lapoltba, Feb 7, 2019.
  1. Jun 11, 2019 at 12:10 PM
    #281
    lapoltba
    lapoltba [OP] Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I should mention, the mounting bracket would be 3d printed. If I can get my printer fairly well calibrated I can print a bunch off and send them with the harness. Regardless I'll share the file for free if anyone wants to print it themselves.
    Pyrotech and tonered like this.
  2. Jun 11, 2019 at 3:32 PM
    #282
    lapoltba
    CT - 06076
    More detailed pictures (also in the first post):
    02Duck, MOC221_, deusxanime and 5 others like this.
  3. Jun 11, 2019 at 4:16 PM
    #283
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's real beauty right there. :cheers:
  4. Jun 11, 2019 at 4:23 PM
    #284
    smdcbr
    smdcbr Well-Known Member
    Passaic county, NJ
    2016 Blue TRD Sport AC M/T
    That looks Nice! I wired my switch so the letter lighting comes on when my head lights are on, instead of all the time, but I may just ditch that and use yours. Not rushing you, but :spending:
  5. Jun 11, 2019 at 4:25 PM
    #285
    lapoltba
    CT - 06076
    Since people need to put this switch in so many different places, it was too difficult to come up with a PnP way to get a dash light circuit. It is easy enough to modify if you want to do it that way though.
    tonered likes this.
  6. Jun 11, 2019 at 5:46 PM
    #286
    lapoltba
    CT - 06076
    Here are some pictures of my initial routing for the harness. The glove box sits right in front of the 4x4 ECU and when it is installed doesn't leave any room for wires to come straight out. I found that I could remove the upper plug from whatever computer is next to it and route the new harness under it and to the right to get it out of the way and secure. From there, the relay wiring can be tucked down toward the kick panel and secured there near where the door wiring exits. It's a nice easy spot to get to in the unlikely event that the relay needs to be replaced. The switch wiring can then be routed anywhere you like from there. It would be trivial to get it up to the overhead console, and easily routed above the glove box to the center console or left of the steering wheel. There is 8 feet of wire for the switch, and any extra can be zip tied to the metal subframe above the glove box.
    I don't think a bracket for the relay is even required. There is a clip to retain it in the socket that isn't on in the pictures.
    IMG_20190611_200219.jpg IMG_20190611_200245.jpg IMG_20190611_200153.jpg IMG_20190611_200304.jpg IMG_20190611_200414.jpg IMG_20190611_200425.jpg
  7. Jun 12, 2019 at 8:45 AM
    #287
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Awesome update!
    I was just going to comment on putting a small zip tie around the relay body and across the underside of the socket to make sure it didn't wiggle it's way loose with vibration. The clip sounds like a much better idea.
    shakerhood and Shellshock like this.
  8. Jun 12, 2019 at 11:35 AM
    #288
    lapoltba
    CT - 06076
    Yep, the clips are like $0.20 each or something silly. If you're super paranoid, you can add a wrap of electrical tape around the clip. I'll snap a picture of it tonight.
    If I have time I will also be looking at final pricing. I am hoping to have a sale post up by the weekend. First two rounds of people that expressed interest I will be sending a group message to with the order form. The vendor says their lead time is only about a week, so the custom buttons may be what determines ship date to everyone.
  9. Jun 12, 2019 at 11:36 AM
    #289
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Hell yeah! Gotta take mine apart soon anyway, knock this out at the same time maybe...
  10. Jun 12, 2019 at 11:37 AM
    #290
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Want this. Thank you for all the work.
  11. Jun 12, 2019 at 1:25 PM
    #291
    lapoltba
    CT - 06076
    b3itz, TeecoTaco, MOC221_ and 3 others like this.
  12. Jun 12, 2019 at 1:28 PM
    #292
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  13. Jun 12, 2019 at 3:22 PM
    #293
    smdcbr
    Passaic county, NJ
    fwiw, this is the one I got from CH4X4 in the "old" blue. The X in the front diff signifies to me it's disconnected.
  14. Jun 12, 2019 at 3:34 PM
    #294
    lapoltba
    CT - 06076
    That's what I originally got, but everyone was saying it was the symbol for the locker, which according to the ISO symbol site I linked is "correct". It doesn't matter to me what people want, so I can make it an option. When I order the custom switches I can order in any quantity, size, orientation, color, and symbol combination.
    https://www.iso.org/obp/ui#iso:grs:7000:2476
    tonered and TeecoTaco like this.
  15. Jun 12, 2019 at 3:39 PM
    #295
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Have a picture of a butt dick, as long as when it's pushed 2wd low is achieved...is all I care
  16. Jun 12, 2019 at 3:42 PM
    #296
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Wait wait wait. Are we back in business @lapoltba
  17. Jun 12, 2019 at 3:42 PM
    #297
    lapoltba
    CT - 06076
    That could be arranged. LOL!
    Acivichb, Noch, Rujack and 3 others like this.
  18. Jun 12, 2019 at 3:43 PM
    #298
    lapoltba
    CT - 06076
    uhh, 2lo was always a thing, it's just taking longer than I would have liked.
    tonered, Shellshock and TeecoTaco like this.
  19. Jun 12, 2019 at 5:12 PM
    #299
    uploadadventure
    Dixon, Mo
    Well... it been a while since we have chatted about it!
    And by we I mean us lol
    tonered likes this.
  20. Jun 12, 2019 at 5:51 PM
    #300
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Get a room! :rofl::rofl:
    Shellshock likes this.
