2LO Plug & Play Harness Discussion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lapoltba, Feb 7, 2019.
  1. Aug 22, 2019 at 5:43 PM
    #341
    Shellshock
    Iowa
    The green one? Into your switch
  2. Aug 22, 2019 at 5:45 PM
    #342
    rubyrod
    rubyrod New Member
    No, that one i think I got, its the other small white connector. I can see from the pictures the larger one, but not quite sure on the smaller one. Hope that makes sense.
  3. Aug 22, 2019 at 6:20 PM
    #343
    smdcbr
    smdcbr Well-Known Member
    Passaic county, NJ
    2016 Blue TRD Sport AC M/T
    right below the larger connector. They're both to the right of the cabin air filter.
    rubyrod[QUOTED] likes this.
  4. Aug 22, 2019 at 6:22 PM
    #344
    smdcbr
    Passaic county, NJ
    welcome to TW btw
  5. Aug 22, 2019 at 9:16 PM
    #345
    rubyrod
    rubyrod New Member
    OH! see it now. Man, what a rats nest of wires lol .
  6. Aug 23, 2019 at 6:05 AM
    #346
    lapoltba
    lapoltba [OP] Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Yes, it is quite packed in there.
    Thanks for jumping in guys. Updating instructions is still on my list. I just haven't gotten to it yet. I will be trying to finish it this weekend, but the honey-do list isn't getting any smaller.
  7. Aug 23, 2019 at 6:45 PM
    #347
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    Did my install today, nice and easy. The wiring harness is worth it's weight to not have to cut the stock wiring! I put my switch in the center switch bank, the blank just pried right out.
    One gripe: the switch "backlight" seems to be wired to ignition and not lights, like the stock switches.
    Thanks lapoltba and big white trd!
    tonered and lapoltba[OP] like this.
  8. Aug 23, 2019 at 6:51 PM
    #348
    lapoltba
    CT - 06076
    That is correct. Backlight is always on for the text. Stay tuned for a simple add on PnP to get stock illumination.
    deusxanime, pinochle, mtip and 3 others like this.
  9. Aug 24, 2019 at 7:26 AM
    #349
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    This is what I love about the community. There is a solution for every problem I can think of! (And between you and KTJO, it is usually PnP too.)
  10. Aug 24, 2019 at 7:42 AM
    #350
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    The depth and breadth of shared knowledge that people bring to the site is great.
  11. Sep 4, 2019 at 10:51 AM
    #351
    Pyrotech
    Pyrotech Well-Known Member
    2low mod installed, tested and verified working...
    install went smooth, one thing that I ran into that I seen mentioned, was when pulling the glovebox, be careful of the upper edge where it is tucked in behind the pad. don't want to just yank straight back, you may tear the pad. but with a gentle wiggle and downward pressure it popped free.
    Took about 90 minutes start to finish.
    tonered likes this.
  12. Sep 4, 2019 at 10:53 AM
    #352
    lapoltba
    CT - 06076
    That pad is actually easy to pop off before pulling on the glove compartment. I forgot to mention that and, I will be adding it to the instructions when I get to them. Right behind it is a good place to tuck away and zip tie the extra swtich wire.
    Pyrotech[QUOTED] and tonered like this.
  13. Sep 4, 2019 at 11:01 AM
    #353
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    For posterity... received, installed and tested with the boat for about a month now.
    No snapped axles. Works great as long as I remember to turn it off before I switch out of 4WD. Otherwise it complains until I restart the truck. I was thinking about a mod to drop the relay out from the 4WD switch so this only needed to be a momentary switch to get it started but then I realized I'm lazy and that's never going to happen or I'd have already done this on my own without fancy harnesses and connectors ;)
    Good enough. It solves my need nicely as is.
    lapoltba[OP] and Shellshock like this.
  14. Sep 4, 2019 at 11:02 AM
    #354
    Shellshock
    Iowa
    I think the best part of this is how fast it is to engage and disengage. Makes it way more convenient
    CorbinDallas, Pyrotech and tonered like this.
  15. Sep 4, 2019 at 11:09 AM
    #355
    BigWhiteTRD
    Ted
    One option is to turn off the 2Lo switch as soon as the truck successfully shifts the transfer case into Low. (as long as you dont shut off truck and restart it expecting it to stay in 2Lo that works fine, it will switch to 4lo on restart unless the 2Lo switch is pushed in or you spin the dial to 2hi)
  16. Sep 7, 2019 at 11:16 AM
    #356
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    0 problems installing, thank you!
    Had a little trouble finding the ecu, but I just grabbed a dental mirror and started reading shit. "Oh, duh there it is".
  17. Sep 7, 2019 at 11:25 AM
    #357
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Looks good how does it work in the manual
    7r41lbr34k3r[QUOTED] likes this.
  18. Sep 7, 2019 at 11:27 AM
    #358
    lapoltba
    CT - 06076
    I know, I'm biased, but it works fantastic in the manual.
    pinochle, tonered, TeecoTaco and 2 others like this.
  19. Sep 7, 2019 at 11:28 AM
    #359
    jake72
    Jake
    N.E. PA
    Thanks, it looks all factory
  20. Sep 7, 2019 at 11:35 AM
    #360
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I have the 5spd 4 banger, fwiw.
    Just took a spin around town and it's exactly what I needed for towing my travel trailer. There just wasn't enough power in 1st to get going(in certain situations), ended up being very hard on the clutch while camping up in Vermont.
    I'm headed up to 11k elevation soon, which really sucks the life out of the 4 banger... not even sweating it now.
    I was taching 3k RPM in 5th gear @ 35mph, which is perfect.
    2 years back, heading into Estes Park, CO from Lyons I had to be going close to 50mph in 3rd to have enough power to accelerate. Not exactly safe when carrying a lot of weight on the twists and turns of N. St. Vrain. I look forward to this trip now.
    tonered, TeecoTaco and lapoltba[OP] like this.
