2LO Plug & Play Harness Discussion
Discussion in '3rd Gen. Tacomas (2016+)' started by lapoltba, Feb 7, 2019.
  1. Feb 11, 2019 at 6:46 AM
    #81
    Vonhetzer
    Vonhetzer Well-Known Member
    Ben
    Northern Indiana
    19 Voodoo TRDP, 97 4RnR SR5, 05 4RnR SE, 17 4RnR ORP, 05 Jetta TDI
    Superficial
    Thank you everyone for the information. I am convinced I need this haha. :spending:
    M1Awolf and lapoltba [OP] like this.
  2. Feb 11, 2019 at 8:09 AM
    #82
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    In my case, the boat ramp I typically use has a hard left turn on asphalt at the top, still on an incline. My boat/trailer combo is right at 6k + whomever is in the boat so in order not to smoke my clutch I am always in 4LO. I always have to stop and put it in 2HI to make the turn and then pull out, uphill around the turn. THis is going to make the whole process a single clutch operation. Or, overload and snap an axle sending the whole mess into the lake. :)
    02Duck and TeecoTaco like this.
  3. Feb 11, 2019 at 4:50 PM
    #83
    Taco16LB
    Taco16LB Well-Known Member
    Pending price and how dificult to install I want this also .
  4. Feb 11, 2019 at 4:52 PM
    #84
    lapoltba
    lapoltba [OP] Well-Known Member
    '17 Sport ACLB V6/6MT OV-Tuned
    Take a look at the PDF in the other thread I linked in the first post. Ignore the part about splicing wires since all you will be doing is plugging in four connectors. The switch can go wherever you feel comfortable getting at, but my preference would be one of the empty center slots below your HVAC controls. If you have basic hand tools it should not be an issue.
    Taco16LB and 02Duck like this.
  5. Feb 11, 2019 at 5:02 PM
    #85
    Taco16LB
    I have the premium and tech package so no empty spaces under the hvac . I have a 2016 so I have an open space under the cubby hole by where the switch for the 400 watt 12 volt is with no rear window slider switch. Also , are there plugs to plug in under the truck by the transfer case and rear end ?
  6. Feb 11, 2019 at 5:07 PM
    #86
    lapoltba
    Gotcha, That location is doable but will require longer wire (obviously).
    The plugs for this mod are behind the passenger side kick panel/glove box. I believe I have located the correct plugs for the e-locker, but I haven't looked for the T-case ones.
  7. Feb 11, 2019 at 5:13 PM
    #87
    Taco16LB
    Cool , I just read the other thread pfd. This should be great for manuvering my pontoon boat in and out of water/driveway etc. Get me on the list please , I have the OR model with the E locker and an AT.
    Cav_BluTRD and lapoltba [OP] like this.
  8. Feb 11, 2019 at 5:26 PM
    #88
    lapoltba
    Added pictures of the two aironboard.com switches to the first post. The "new blue" is definitely a better match. The regular blue is quite bright as you can tell from the lens flare. I think either would be fine, but it is unfortunate that they are in short supply.
    Taco16LB, BigWhiteTRD and TeecoTaco like this.
  9. Feb 11, 2019 at 6:08 PM
    #89
    Cav_BluTRD
    Cav_BluTRD Well-Known Member
    Rich
    St. Louis, MO
    2019 Calvary Blue Tacoma TRD Off Road
    I like the new blue too @lapoltba
    I gotta have my switch to the left of the steering wheel too. Damn. No open places in the middle.
    lapoltba [OP] likes this.
  10. Feb 11, 2019 at 6:12 PM
    #90
    lapoltba
    I expect there will be enough interest in both locations I can offer both as an option. The third option would be no switch included with just a length of wire at a lower price.
    The other switch I am waiting on only had one blue to choose from and I don't know what shade it is. Those wanting the new blue from air on board may have to get the no switch version and wait for it to be available if they sell out.
    Cav_BluTRD likes this.
  11. Feb 11, 2019 at 6:22 PM
    #91
    Taco16LB
    It really does not matter to me what color the switch is . So long as all is plug and play and for by the 400 Watt 12 volt switch left of the steering wheel . I do not need the locker if that was an option , just 2 wheel low.
    Just curious though , If we switch into 2 wheel low , what would all have to happen to then go to 4 wheel low ?
  12. Feb 11, 2019 at 6:27 PM
    #92
    lapoltba
    @BigWhiteTRD will have to confirm, but I believe you will have to go back to 2wd as described in his pdf (after deactivating the mod switch). Then go to 4 lo normally. I do not believe the ecu will engage the front disconnect after you go to 2 low even if you release the switch.
    tonered and Taco16LB like this.
  13. Feb 11, 2019 at 7:48 PM
    #93
    RushT
    RushT Well-Known Member
    North Texas
    Inferno DCSB OffRoad
    And......
    sub'd for pricing.
  14. Feb 12, 2019 at 3:54 AM
    #94
    BigWhiteTRD
    BigWhiteTRD Well-Known Member
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto, 4wd w/2 whl Lo mod
    So I only tested the 17 AT, so there MAY be other sequences that people find work.
    The one method that I am sure will work on everyone's 3rd gen is to deactivate 2lo switch and switch truck back to 2hi. Then switch back to 4lo, etc as desired.
    On my truck, deactivating 2lo switch, and power cycling (shut off and turn back on) would also work. But I dont like doing that as I dont like shutting off and restarting, and my mode changes are iffy when sitting perfectly still. (Therefore this isnt a 'recommended' method.)
    Other methods COULD work, but I haven't tested them... like maybe remove power momentarily from ecu, etc.... I am not planning to try anything else. The recommended method is the safest for the truck I believe (thinking of some recent thread with exploded front diffs, etc)
    Taco16LB and tonered like this.
  15. Feb 12, 2019 at 4:08 AM
    #95
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2016 TRD OR M/T, 2017 Panigale 959
    35s on a Lease
    Put me on the interest list, this is a great idea. I have a 16 OR manual, and dont care which size switch as I'll be drilling a new hole for it anyway
