2nd Gen 2.7 manual 5spd question?
Discussion in '4 Cylinder' started by WPDAWG11, Jul 19, 2013.
  1. Jul 19, 2013 at 4:44 PM
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    So I find this transmission to be one of the most temperamental I have ever driven. It gets pretty jerky with the AC running on high. Anyway no way I would have gotten an auto so I digress.
    On a regular start do you just ease the clutch out without gas or do you give it gas while releasing or do you do it some other way?
  2. Jul 19, 2013 at 5:45 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Get familiar with the point where the clutch starts to engage, this part might be the key.
    At that point I give it light throttle and continue to let out. I don't ease it out, neither do I just drop it though, perhaps about 3/4 a second for the process.
  3. Jul 19, 2013 at 5:50 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    What problem?
    I removed my AC... and the power steering too. :anonymous:
  4. Jul 19, 2013 at 7:01 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Yeah this is what I have done with every other 5spd I have driven but seems outlandishly tricky on this truck. Is it just my truck or am I crazy lol
    Oh man it has been like 100+ here. And none of that pussy dry heat either.:)
  5. Jul 19, 2013 at 7:11 PM
    Tacoyota
    08 4wd
    I looked at what I sad and went ... " well, no shit.." to myself hehe.
    I do just fine with the 5 spd,but it does seem like everything is off timed and quirky.
    Consider pulling 2ndary air filter, adding a AFE pro dry filter and pulling the baffle in the fender. I can't say I felt power gains, but I did find the engine & clutch operation to go smoother at a stop.
  6. Jul 19, 2013 at 7:15 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Quirky is a good word to describe it. I will have look into that fender for sure. I miss my dakotas transmission but not the truck lol
  7. Jul 22, 2013 at 11:25 AM
    JHG57
    JHG57 Active Member
    James
    Oviedo, Florida
    I must not know how to shift, I don't have any problems with my 2.7 manual 5 spd. ... :D
  8. Jul 22, 2013 at 2:32 PM
    WPDAWG11
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    Found out there is an actual issue with my clutch
  9. Jul 22, 2013 at 2:39 PM
    tooter
    Greg
    Los Angeles
    I'm glad you did find something actually wrong... :)
    ...because normally the clutch is exceptionally easy to slip to get the vehicle rolling and the 5 speed transmission shifts smooth as butter.
  10. Jul 22, 2013 at 4:43 PM
    JHG57
    JHG57 Active Member
    James
    Oviedo, Florida
    Clutch issue explains it.
  11. Jul 22, 2013 at 9:15 PM
    Gapup
    Gapup New Member
    Earl
    Pac NW
    Plain vanilla
    You aren't alone. I had an '01 conventional cab with a 2.4/5spd. On occasion, I would stall the engine in traffic but over the course of 6 years, that only happened a few times.
    Fast fwd: This past April I purchased a used '07 access cab with a 2.7/5spd with only 17k on the odometer. In these past 3 months I've stalled that engine far more than I ever did in the 6 years I had previous rig.
    Suspects: Clutch and my hearing impairment. This rig is substantially quieter that the conv. cab was. Thus, in traffic with mucho noise around me, I can't gage RPM by sound and the 2.7 is not only very quiet but it's also absolutely the whimpiest engine I've ever encountered. If the RPM is not raised over 1000, it will give a few orgasmic jerks and collapse, like suddenly.
    Then there is the clutch. From the very first my physical reaction to clutch engagement has been that it does not have smooth curve to clutch engagement. It begins to take up smoothly enough BUT at a certain point wants to complete the engagement very quickly and ..... as they say ..... that's when the trouble begins....... especially if the engine is not on a stronger portion of the torque curve. It's even worse, of course, if the rig on an incline.
    To my mind, the clutch pedal really feels like its moving an over-center mechanism of some sort. Graduated movement and response ... UNTIL it reaches a certain point and then it's suddenly a solid lock up.
    More torque at low RPM would be move in the right direction.
  12. Jul 23, 2013 at 8:06 AM
    Yoshio
    Yoshio Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    I was thinking this might be the case, my 4 cyl 5 speed is one of the smoothest clutches I've driven... but then again I can only compare it to a 89 trooper, 99 eclipse, and 05 forester
  13. Jul 24, 2013 at 4:25 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2:D
  14. Aug 25, 2013 at 5:59 PM
    tacoma4
    tacoma4 Well-Known Member
    What was the issue with your clutch? Curious if mine might have the same problem.....
  15. Aug 27, 2013 at 7:28 PM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    mine was very similiar. in a nutshell, there were weak clutches on the 2.7. when i first got my truck i posted about notchy shifting, it was fairly annoying.
    then the clutch just gave up one day, and the dealer warrantied it. since then, it has shifted perfectly.
  16. Aug 28, 2013 at 8:37 PM
    tacoma4
    Bastards at the dealership won't change my clutch :mad:. They claim they "cannot duplicate customer issue" and tried to charge me $90. I didn't pay that but they won't put a new one in and I'm about out of warranty. Might have to put one in on my dime now :rolleyes:.
  17. Sep 4, 2013 at 1:57 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    what was the issue....
    should be able to get it going without touching the gas.
  18. Sep 4, 2013 at 3:02 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    First I will say that the quality of the clutches in the 2nd gen 5 speeds ranges from horrible to excellent. I would say mine is average. The only real issue mine has, is that when it sits out in the rain, engagement is not smooth for at least a few stop and starts.
    At the other end of the spectrum, at times I can get moving from a dead stop without applying any throttle when it is fully warmed up. When a long line of traffic starts moving when a traffic light turns green, I have noticed that this is possible.
  19. Sep 6, 2013 at 9:58 PM
    FTD
    FTD Well-Known Member
    Glad to hear the problem was actually a problem. My Tacoma clutch is the second-nicest I've ever driven. First would be a 911, but that's a bit unfair to even compare a truck to a Porsche.
