2nd Gen. 2012 Toyota Tacoma Model: GRN245L-PRADKA Specifications
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Proyota, Feb 15, 2014.
  1. Feb 15, 2014 at 8:20 AM
    Proyota
    Proyota [OP] Well-Known Member
    Brad
    Hamilton, MT
    2012 Tacoma DBSB TRD Off-Road
    Icon Suspension, Extended Rear Brake Lines, FN Wheels, PIAA, Rigid Industries & Baja Design Lighting, Warn Winch, All Pro Off-Road Front & Rear Bumpers and All Pro Off-Road Rock Sliders, Budbuilt Skid Plates, BAMF LCA Skids & Diff Guard
    2012 Tacoma Dbl Cab 4wd
    Engine 4.0L V6 (1GR-FE)
    (241.4 cu.in.)
    Engine Oil
    Type: 5w30
    Oil Capacity: 5.5 qt.
    Cooling System
    Type: Toyota Super Long Life
    Capacity: 10.1 Quarts
    Spark Plugs
    Type:
    Denso K20HR-U11
    NGK LFR6C11
    Gap: 0.043 in. (1.1mm)
    Automatic Transmission
    Model: A750F
    Fluid Type: Toyota ATF WS
    Capacity: 11.5 qt. (10.9 L)
    With Towing Package
    1st Gear Ratio: 3.520
    2nd Gear Ratio: 2.042
    3rd Gear Ratio: 1.400
    4th Gear Ratio: 1.000
    5th Gear Ratio: 0.716
    Propeller Shaft
    Type: Lithium Grease NLGI No.2
    Power Steering
    Type: ATF Dexron II or III
    Differentials
    Oil Type: LT 75W-85 GL-5
    Capacity:
    Front 1.58 qt. (1.5 L)
    Rear 3.12 qt. (2.95 L)
    Torque Specifications:
    Ft Diff Drain Plug: 48 ft lbs.
    Ft Diff Fill Plug: 29 ft lbs.
    Rear Diff Drain Plug: 36 ft lbs.
    Rear Diff Fill Plug: 36 ft lbs.
    Transfer Case
    Oil Type: SAE 75W-90
    GL-4 or GL-5
    Capacity: 1.1 qt. (1.0 L)
    T-Case Drain Plug: 27 ft lbs.
    T-Case Fill Plug: 27 ft lbs.
    OEM Wheel Specifications:
    TRD Off-Road Wheels: 16x7, +32mm Offset, 5.25” Backspacing, 6 x 5.5” Bolt Patterns
    Front / Rear Wheel Lug Nuts: 83 ft lbs.
    OEM Tire Size: 265/70R16
    GVWR 5500 lbs
    Tow Rating: 6500 lbs.
    Lighting:
    Headlights: 9003 HB2
    Fog Lamps: H11
    Sidemarker: 5w wedge base bulbs
    Front Turn Signals: 4157 NAK
    Rear Turn Signals: 3157A / 3157 KX
    Back-up Lamps: 921
    License plate Lamps: 921
    CHMSL: 5w wedge base bulbs
    Rear Differential Breather:
    Union / Toyota Part # 90404-51026
    Upper Control Arm x Steering Knuckle: 81 ft lbs.
    Lower Control Arm / Lower Ball Joint to Steering Knuckle: 118 ft lbs
    Steering Knuckle x Front Axle Hub: 147 ft lbs.
    Tie Rod End x Steering Knuckle: 67 ft lbs.
    Note: Install New Cotter Pin
    Tie Rod End Lock Nut: 41 ft lbs.
    Note: Toe Adjustment
    Front CV Axle Hub Nut: 173 ft lbs.
    Note: Install Nut Lock and New Cotter Pin
    Front Differential Drain Plug: 48 ft lbs.
    Front Differential Fill Plug: 29 ft lbs.
    Rear Differential Drain Plug: 36 ft lbs.
    Rear Differential Fill Plug: 36 ft lbs.
    Transfer Case Drain Plug: 27 ft lbs.
    Transfer Case Fill Plug: 27 ft lbs.
    Tools:
    Front CV Drive Axle Nut is 35mm Socket
    Ft Diff Drain / Fill Plugs 10mm Allen
    Rear Diff Drain / Fill Plugs 24mm Socket
    T-Case Drain / Fill Plugs: 24mm Socket
    Please add to the list if you have any information to contribute... Thank you!
  2. Feb 15, 2014 at 11:18 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    Those are some handy torques!
    PatsNWtaco likes this.
  3. Feb 15, 2014 at 11:26 AM
    Proyota
    Brad
    Hamilton, MT
    Thanks. I'm just tryin to put together a list of the most common torq specs used.
  4. Feb 15, 2014 at 2:45 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    thanks for posting all that..good stuff to save
  5. Sep 10, 2018 at 6:37 AM
    Fishing_Fool
    Fishing_Fool New Member
    2012 Tacoma TRD
    3" lift
    This is all super helpful info, thanks!
