2nd Gen 2Lo Mod?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beyota, Jan 1, 2025.
  1. Jan 1, 2025 at 10:22 AM
    Beyota
    Beyota [OP] New Member
    Brett
    2012 Toyota Tacoma TRD Sport 6man
    Hey all! I'm looking for this mod for towing, specifically for the reverse issue. Someone had a plug-and-play module on here for sale but sold out? Where can I get one?
    TY!
  2. Jan 1, 2025 at 10:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    They occasionally pop up in the marketplace section but as far as I know @Up2NoGood has no plans to make any more and no one else I know of has anything comparable.
    Naveronski likes this.
  3. Jan 1, 2025 at 12:46 PM
    Jon916996748
    Jon916996748 Active Member
    Atlanta, GA
    V6 4x4
  4. Jan 1, 2025 at 2:54 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For temporary use, (backing a trailer uphill) just use 4 lo.
    It was very easy to shift into 2lo with old school 4X4's that had 3 sticks in the floor and locking hubs. They also put warning labels on the dash warning drivers not to do so. I've seen guys snap U-Joints doing it. They no longer put the warning labels on newer trucks because it's impossible to do so unless you modify the truck.
    Naveronski and Ricardo13x like this.
  5. Jan 1, 2025 at 6:47 PM
    Pigpen
    Dan
    Northwest Montana
    The plug and play 2lo mod is awesome. Bummer, if he's not doing them anymore. I'll be holding on to mine until I get a tacobox from Marlin, which won't be in the budget for a loooong time!!
    Dm93 likes this.
  6. Jan 1, 2025 at 6:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Some of us don't like hacking up our factory wiring.
    Your really unlikely to damage anything in 2wd low unless your being stupid and trying to move something that is way too heavy for the truck on a high traction surface, your more likely to hurt something trying to maneuver in a tight space in 4wd low.
    Yea would have been nice if he would have published the schematics so someone else could produce them since he's not going to but I can understand why he won't.
