2nd Gen 3-link rear suspension
Discussion in 'Long Travel Suspension' started by BMiller421, Oct 31, 2019.
  1. Oct 31, 2019 at 12:01 PM
    BMiller421
    BMiller421 [OP] FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    So I'm really wanting to pursue a 3 link w/panhard bar setup for my 05 Access cab.
    Looking for any information/pics/specification/calculations/etc. that anybody has.
    Any past/current build links I can refer to, I would appreciate it.
    3pooches likes this.
  2. Oct 31, 2019 at 1:21 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    BMiller421[OP] and Hawk373 like this.
  3. Oct 31, 2019 at 7:55 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Have no association or knowledge of there work but you could also check out https://www.otwellweldingandfabrication.com/ Just down the road from both of you. They are in Lucerne Valley. I would avoid a 3-link with panhard rod. Ok for minimal travel vehicles but keep in mind as the axle moves thru it's travel the axle also moves laterally. Go 4-link or just do a long travel leaf spring set-up.
    BMiller421[OP] likes this.
  4. Nov 1, 2019 at 3:58 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Here are a couple of links with articles/calculators.
    https://www.crawlpedia.com/4_link_suspension.htm
    https://www.patooyee.com/calculators/calculators.htm
    Also, check out the SAS subforum. Most that SAS their trucks do a 3-link in the front, so they will have some good info/in sight. Linking the rear will be the same general concept as the front.
  5. Nov 1, 2019 at 8:57 AM
    dirt designs
    dirt designs Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    Not true. The panhard 3 link setup we built has very low amount of side travel (~1.5" side to side). On paper maybe you can debate that sounds like a lot but we have put these on 6 trucks now and no one has ever even felt the side movement. No one feels it because 1" of movement is in the last 2-3" of bump and droop which you are either fulling bumping out (hard load so you feel the G's) or you are airborne. Our kit works with stock gas tank, stock axle, and stock driveline. Buy the kit, shocks, install, and build your own bedcage.....done. Leaf springs are terrible ride compared to a linked truck. Hopefully someday soon trucks will stop coming with them from the factory.
  6. Nov 1, 2019 at 3:03 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The current Rangers have a watts linkage I was reading. It said a watts link is better for reducing off-center swaying over a panhard bar. Would a watts link be ineffective / impractical in this application? Maybe get in the way of the gas tank?
  7. Nov 1, 2019 at 3:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I had no idea what watts linkage so I watched a video on it, and this has started me down a rabbit hole of different links systems. It's interesting for sure.
  8. Nov 1, 2019 at 3:19 PM
    dirt designs
    slo
    Watts link is definitely for lower travel suspensions. I did try to design with a watts link originally but I had to make the pivot arms in the middle very tall (~14" arms) to accommodate the amount of suspension travel. With the arms that long, they would have hung below the axle ~6" or more which is not going to work offroad since they would get ripped off first trip. After figuring out how big the pivot had to be, there was really no where to fit it. Either it would drag on the ground or it would end up in the middle of the bed
  9. Nov 1, 2019 at 6:43 PM
    WalkinTaco
    WalkinTaco Well-Known Member
    2018 TRD OR M/T
  10. Nov 1, 2019 at 6:44 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  11. Nov 1, 2019 at 7:00 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  12. Nov 1, 2019 at 7:02 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I’ve been running mine 3 linked for a few years and absolutely love it. Anyone talking about the side to side movement or limited travel is regurgitating old wives tales and not speaking from personal experience. Mine was a “driveway fab” first time build and it pulls 20” with just 12” CO’s, if I would have given up some bed space and gone for 16’s you could add a foot to that travel #.
    Steve’s kit is incredibly well designed and fab’d I would highly suggest that you look at the @dirt designs kit.
