2nd Gen Base upgrading to 2nd Gen TRD Off Road suspension
Discussion in 'Suspension' started by RodsInTheTacoma, Feb 27, 2020.
  1. Feb 27, 2020 at 4:48 PM
    RodsInTheTacoma
    RodsInTheTacoma [OP] Member
    Jay
    South-Western Ontario, Canada
    2011 Tacoma Base 2.7L 4x4 Access Cab
    Hey guys. I have a 2011 base 2.7L 6lug. It has 300k kms. Still has the original blue/yellow bilsteins on it (atleast I'm pretty sure as they say Toyota bilstein... this might be a question for you guys also). Fyi - they are still going and I'm very surprised...
    Anyway, I have a set of shocks with low kms that I got off a 2012 trd off road. My goal is just for ride comfort so I figured these off roads might be my best bet. Not going for a lift at all. My question is, is there a difference in the bilsteins I have on my 2011 Base now compared to the 2012's Trd off roads? Is it just the coils or valving? I'm wondering this because they look so similar visually.
    I have looked around for an answer with no luck. Not trying to spend much more in this truck as I plan to sell and get a double cab in the next year or two.
    Thanks folks.
  2. Feb 27, 2020 at 10:10 PM
    RodsInTheTacoma
    Jay
  3. Mar 3, 2020 at 1:59 PM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    https://www.tacomaworld.com/threads/review-3rd-gen-suspension-on-2nd-gen.542843/
    I would get a 3rd gen take-off. You can usually get low mileage front (fully assembled) and rear for around $250 from a 3rd gen guy putting on a lift.
    I would recommend getting it off the TRD Off-Road if you want a smoother ride, if you want better handling get then TRD Sport suspension. Either way the front will raise about 1"-1.5" as well.
  4. Mar 3, 2020 at 7:48 PM
    RodsInTheTacoma
    Jay
    Yeah. I figured that route is best. However, I already have the 2012 off road shocks on hand. Also, seems hard to come across these parts in Canada lol.
    Just not sure what exactly the difference is between the 2 trucks ? They look the exact same.
  5. Mar 3, 2020 at 7:51 PM
    Bishop84
    Bishop84 Well-Known Member
    Your truck came with black shocks, someone put those bilstiens in.
    Only sport and O/R have the yellow. It will ride better, but I'd look for new shocks off a 2016+ model as well.
    RodsInTheTacoma[OP] likes this.
  6. Mar 3, 2020 at 7:55 PM
    RodsInTheTacoma
    Jay
    Oh really? Could very well have. I thought the 2011 base would just come with the stock Toyota bilsteins.
    Thanks!!
  7. Mar 4, 2020 at 4:31 AM
    TacoFergie
    Iowa
    My truck is a 2015 TRD Sport and I installed TRD Off-Road from a 2017 iirc. The 3rd gen suspension was revalved a little bit to refine the ride over the 2nd gen. Also with a higher spring rate than the 3rd gen, thats where the small lift comes from. But it isn't a worse ride due to stiffer springs like one would imagine. The magic is in the shock/strut valving. The Off-Road suspension is quite a bit smoother overall.
