2nd gen bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by norcal4banger, May 24, 2011.
  1. May 24, 2011 at 12:18 PM
    norcal4banger
    norcal4banger [OP] 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    Are the beds just plastic? Or is there metal between the plastic? I'm designing a bed rack so I can haul more than just my dog's kennel in the back. I want to put 4-8 bolts in the bottom of the bed to hold this thing up. What problems am I going to run into with this if any?
  2. May 24, 2011 at 12:28 PM
    norcal4banger
    Jack
    Anyone really quick before I take off to go to the fab shop?
  3. May 24, 2011 at 12:28 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got d-rings that I added in the rain water drain holes in the front of the bed. I drilled them larger and put in some d-rings. They've held up great supporting the motorcycle.
    To directly answer your question, it's a composite. I'm not 100% sure what it is but it is magnetic (at least the back posts inside the rear tail lights are because you can get a good electrical ground there).
    Depending on the stress you think this thing will see, put a plate washer on the bottom side and you'll be good to go.
  4. May 24, 2011 at 1:45 PM
    norcal4banger
    Jack
    But how would I get to there from the bed?
  5. May 24, 2011 at 1:59 PM
    Pugga
    Massachusetts
    It might help if we knew what you were attempting and where you intend to mount it. The bed is fairly strong and you can drill it and use thru-bolts. Use a backer plate or a washer if you can, it'll only make it less likely to fail. You can crawl under the truck and stick a washer and nut on whatever you're bolting to the bottom of the bed.
  6. May 24, 2011 at 2:03 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    When I added extra d-rings I backed them with 4" x 4" x 1/8" stainless from beneath to spread out the stress points.
    Drill a pilot hole and then go larger.
  7. May 24, 2011 at 2:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Its just a composite bed, no metal.
  8. May 24, 2011 at 2:14 PM
    meirvin
    meirvin Today was a good day, I didn't have to use my AK
    Dallas/Fort Worth
    TRD Sport LB
    Tinted Windows, HomeLink, Kennwood 7180 Navigation, DIAMOND AUDIO D161.5 6.5" Component Speakers- front, DIAMOND AUDIO D161.5i 6.5" Coaxial Speakers-Rear, Rockford Fosgate P 400-2, Rockford Fosgate P 400-4, JL subwoofer, Viper 5902 remote start/alarm, Coverall Bed Cover, Magnaflow Muffler, Redline Hood Struts
    but to answer your question Yes it is some kind of High strength composite plastic
  9. May 24, 2011 at 3:07 PM
    norcal4banger
    Jack
    I don't really know how to explain it well, but its a basket rack that will have for legs. The four legs will be bolted to the bed through flat pieces that welded to the bottom of each leg. I'll either do 1 to 2 bolts for flat piece that holds the legs. I don't know if that makes sense or not but the guy said in about a week or so it'll be done. I'm not sure which size bolts I will use but I know there is going to be a big washer and lock washer underneath the bed. Sorry if this doesn't make a lot of sense. But hopefully you get the idea
  10. May 25, 2011 at 6:32 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I'd put flat plates (same size as the ones welded to the legs or even a little larger) also under the bed and sandwich the bed between those plates. I'd assume one thru bolt in each plate would be plenty. Depending how big these 'plates' are I wouldn't want holes in the composite too close to each other.
  11. May 25, 2011 at 7:01 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Sorry to thread jack .. Where did you get the D-rings from? I would love to add 2 more to the front of the bed.
  12. May 25, 2011 at 7:05 AM
    LTE
    LTE NRA Benefactor Member
    in my own little world
    07 SR5II; Longbed; FLyzeyes LED
    window tint, step bars, Flyzeye LED interior console light
    I did this as well.
  13. May 25, 2011 at 7:16 AM
    Pugga
    Massachusetts
    I bought a set from Toyota. The same ones that are mounted in the rear of the bed. There are other other aftermarket options that work well, I belive military surplus is a popular choice and strong as hell!
  14. May 25, 2011 at 8:13 AM
    LTE
    Someone has a thread on this forum that they have a source for the D rings and they are much cheaper than Toyota D rings.
