2nd gen best and worst years?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluezzy, Feb 26, 2016.
  1. Mar 2, 2016 at 10:19 AM
    #61
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Love my 08. 129k no issues to speak of. I have never wanted for the 2nd gen upgrade or a 3rd gen. I plan to keep her till the end of her days.
  2. Mar 2, 2016 at 10:40 AM
    #62
    TacoPhil
    TacoPhil Excuse me while I go out and watch the grass grow
    2013 4x4 TRD OR
    Wheelbases come in 3 diff. lengths:
    109.6" reg. Cab
    127.4" Access Cab & Dbl. Cab short Bed
    140.6" Dbl. Cab Long Bed
    http://www.cars.com/toyota/tacoma/2013/specifications/
  3. Mar 2, 2016 at 10:46 AM
    #63
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Probably the 3 best/most common options:
    1. OEM Bed Mat - Best look with "Tacoma" text in my opinion. Tough as nails. Reinforced with fibers (I cut my bed mat to fit some tie downs and noticed this). I bought mine for roughly $90 shipped.
    2. Horse stall mat from a place like Tractor Supply or ACE hardware, cut to size: REALLY tough as nails (at least an inch thick or so). Relatively cheap, heavy as hell though, and don't fit the bed as perfectly as the OEM mat.
    3. 3rd party mat like DeeZee or something. You may have to cut some of these to fit if you have a short bed. On the thinner side. Most people still say they hold up good. Not that much cheaper than the OEM mat...I currently see them around the $80 mark.
    I'd vote OEM mat. That and my OEM cargo net have been great investments and quality items.
  4. Mar 2, 2016 at 10:55 AM
    #64
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    09 and up gives you traction control and rear camera as standard options. 09 to maybe 12 gives you built in sat. radio antenna (the "blob" on the rear).
    This is going to depend on your area and current prices. I bought an 09 3 years ago for $24,000 with only 19,000 miles on it. At the time that was easily $10,000 less than any other new tacoma I could find.
  5. Mar 2, 2016 at 11:47 AM
    #65
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    With my '14, there are a few creature comforts items I thought would be standard that aren't. Sounds like the rear view mirrors had more features in previous years. No temp gauge bothers me for some reason and I don't even need one... living in San Diego its 70 all the time :)
  6. Mar 2, 2016 at 1:34 PM
    #66
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I've owned both an MY12 and an MY13. Exact same features but the '13 Bluetooth, head unit, stereo and steering wheel controls all function much better.
    Also '13 is the last year for the auto dimming rear view with temperature and a back up camera (where it should be!).
    You also get a clock!!!
  7. Mar 2, 2016 at 2:30 PM
    #67
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Well that sucks for my 09 Prerunner. I bought it last year and so far no issues. What makes the 09 "the worst"? Is there anything I should look at or be doing preventative maintenance wise? I've changed out most of the fluids and have been changing the oil well before I hit the 5k interval.
  8. Mar 2, 2016 at 2:47 PM
    #68
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    nothing you can do, your doomed.................(sarcasm)
  9. Mar 2, 2016 at 3:19 PM
    #69
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    2013 for sure.
    You get the latest and greatest with all of the fixes.... but you still get your stand alone clock, auto dimming mirror, rear view mirror with back up cam and proper outside temp display.
    gimmeajo likes this.
  10. Mar 2, 2016 at 3:33 PM
    #70
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    I may be biased because ive got an 09 but...over the years that ive been reading on TW, always thought the 09's had the least amount of problems. Had the TSB done for leaf springs, reflash bad 1-2 shift for transmission and replaced radio as it was possessed. Otherwise been great. Have had problems with some suspension mods but stock it was fine.
    1Shifter[QUOTED] likes this.
  11. Mar 2, 2016 at 4:44 PM
    #71
    1Shifter
    Jeff
    09 PreRunner
    The radio was replaced by the previous owner but agree it still sucks. No issues with my transmission or leafs yet. Like I said so far the truck has been rock solid. Thanks for the feedback.
    Armkb[QUOTED] likes this.
  12. Mar 2, 2016 at 5:08 PM
    #72
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I have 2012, I to liked the feature mix and thought Toyota would have had things perfected by now on the 2nd gen. Granted it's a solid built truck, 54k and not a rattle but it hasn't been problem free. I see so much hate on this forum for the other makes, but my past Chevy's were never at the dealer as much as this truck or had a major failure before 100k as this truck, here's my list.
    Rear brake squeal-tsb fix
    Takeoff vibration-tsb fix
    Engine pinging- ecm reflash fix
    Secondary air injection valve code @29k tested by dealer, cleared code told me it was fine.
    Secondary air injection valve failure @ 53k truck in limp mode- no warranty coverage, fixed on my dollar.
  13. Mar 3, 2016 at 10:10 AM
    #73
    ThatNachoGuy96
    ThatNachoGuy96 Member
    Nacho
    2008 SR5 4.0L V6 DCSB
    Body Armor 4x4 front bumper 12,000 lbs capacity winch 3/4" D-ring Shackles FlowMaster® 40series DeltaFlow Muffler AVS® Hood shield IPCW 3rd Brake Light LED IPCW LED Tail Lights LT265/75/R16 BFG KO2s
    I own a 2008 base Tacoma. No problem whatsoever in the year and 11,000 miles I have had her. Plan to keep her to the end of days.
  14. Mar 3, 2016 at 10:16 AM
    #74
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Love my 2012 TRD Sport Prerunner!:thumbsup::yes::yay:
  15. Mar 3, 2016 at 10:26 AM
    #75
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    What exactly was the symptoms of the rear brake squeal? My '14 makes an intermittent squeal somewhere from the rear that doesn't seem to be suspension related. Its very faint and just randomly squeals...
  16. Mar 3, 2016 at 10:27 AM
    #76
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    It has been scientifically proven that '13 is the greatest year.
    xbxb, TheRealKrobar and KB Voodoo like this.
  17. Mar 3, 2016 at 10:51 AM
    #77
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  18. Mar 3, 2016 at 2:12 PM
    #78
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    2007 - 2008 most likely the best year.
    They have stronger engine mounts and better head gasket than 2005-2006.
    They do not have a smog pump and eletronic nannies that 2009+ have.
    shakerhood and 1rooster like this.
  19. Mar 3, 2016 at 4:27 PM
    #79
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    It would squeal just at the end of the stop , wasn't random ad happened every time.
  20. Mar 3, 2016 at 5:48 PM
    #80
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Ahh but the 2005s that got a new frame got the new mounts as well. I stand by my statement. But all Tacomas kick ass so what are we really arguing about. Rock on!
