2nd Gen Breakover Angle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NAYo2002, Apr 11, 2010.
  1. Apr 11, 2010 at 11:01 PM
    NAYo2002
    NAYo2002 [OP] Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    I found something weird on Toyota's official spec's for the Tacoma: http://www.toyota.com/tacoma/specs.html (click on dimentions tab)
    If you compare between Double Cab SB and Access Cab, AC has 24 degrees of Ramp Breakover Angle as oppose to DC's 21 degrees. I find this to be very strange considering I thought DC and AC have the identical frame and underbody. Am I missing something?
  2. Apr 11, 2010 at 11:10 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Wouldn't Weight difference affect it?
  3. Apr 11, 2010 at 11:35 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The frame might be the same...but due to the cab structure, crossmembers might not be in the same location between the two.
    That's just a guess....
  4. Apr 12, 2010 at 12:55 AM
    NAYo2002
    Great Falls, MT
    Maybe.. since they take these angles at curb weight, DC might be a little heavier and sit a tad lower.
    Could be as Janster suggested... but I looked underneath the center point between two wheels on my DC and I don't see any structures that sits lower than the frame at that point.
    I'm just making sure I'm not missing something in detail.
  5. Apr 12, 2010 at 5:33 PM
    NAYo2002
    Great Falls, MT
    Bump for some answers :eek:
  6. Apr 14, 2010 at 6:25 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Well the wheelbase are exactly the same; 127.4
    So the only thing that would change the Ramp breakover angle is the height.
    The curb weight of the DC is only 110 lbs more than the AC. I can't beleive that 110 lbs would cause the truck to set lower.
  7. Apr 14, 2010 at 6:48 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    According to Toyota even the weight of the trailer hitch can alter things! They even put a "yellow" sticker in the door jamb to alert you to that fact. So I am not surprised that 110 lbs can stress the great factory springs!
