2nd Gen Cruise control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoytoda, Oct 22, 2009.
  1. Oct 22, 2009 at 4:56 PM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I have read every thread i could find, many of them old, and was wondering how many people have had success in retro fitting cruise into 09/10 tacomas. They seem to lack alot of neccessary wiring. I have extensive experience with electronics but it would be much easier to see if anyone has done this and hear there experience instead of disassembling my dash to reverse engineer the system. So far i have installed the power wire for the cruise and the power wire for the cruise light, as well as the ground wire. But, before i go spending money on a stalk and clutch switch i have to figure out how to retro fit the clutch switch w/o the stock wiring for it. Anyone?
  2. Dec 23, 2009 at 1:57 PM
    Wanderer32
    Wanderer32 Member
    Homeless
    09 Tacoma 4x4
    Camburg front suspension lift, OME rear lift
    I too am looking to fit cruise control to an 09'. Does anybody know if it is it as simple as the older models or is there more wiring and parts involved? Thanks.
  3. Dec 24, 2009 at 10:53 AM
    Yoytoda
    Roland
    completely stock
    many things are similar but i lack the clutch switch wiring. i may have to run the wires all the way to the ECU behind the glovebox for the clutch switch and the cruise wiring...
  4. Dec 24, 2009 at 8:41 PM
    snyder
    snyder Active Member
    none, dont want to void the warranty
    Why didnt you just buy your Tacoma with the cruise control already installed in it? I use my cruise control all the time on long road trips.
  5. Dec 24, 2009 at 8:44 PM
    Yoytoda
    Roland
    completely stock
    because its not offered on new reg cabs iirc
  6. Jan 11, 2010 at 3:17 PM
    Fast_Fred
    Fast_Fred New Member
    Illinos
    Tacoma
    I have gone through the process of adding cruise to my 09 per a posting on ToyotaNation for a 2005+. I installed everything but could not locate the connector for the clutch switch. After disassembling the lower portion of the dash, I finally concluded that it was just not there. Anyone know if there is anything else missing on the 09 in addition to the the wiring for the clutch switch? What's the deal with the cruise light? Is that in the speedometer?
  7. Jan 11, 2010 at 3:38 PM
    Wanderer32
    Wanderer32 Member
    Homeless
    09 Tacoma 4x4
    The cruise light is a green light that says "cruise" within your instrument panel. I believe it is below the speedometer. It comes on when you press the on button on the cruise control stalk. Can't help you with the clutch switch as mine is an automatic. I got lucky in that my truck was already wired like the older models. Didn't have to use the extra wiring that came with the Rostra cruise control kit for the 09.
