2nd Gen DIY Big Brake KIt -OEM parts- Part #'s provided (INSTALLED)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by craigFLA, Jul 31, 2016.
  1. Feb 27, 2019 at 9:44 AM
    #241
    raco.the.taco
    raco.the.taco Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    That's exactly why i'm doing this right now. Just waiting for all the parts to get here.
  2. Feb 27, 2019 at 9:47 AM
    #242
    raco.the.taco
    Chad
    Denver, CO
    I feel like i saw a video where you just need to trim the dust shield a tad to fit the 4runner calipers. Can anyone confirm that? If i can avoid replacing my dust shields i would like to.
  3. Feb 27, 2019 at 9:47 AM
    #243
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    I’ll probably start gathering the list of parts and ordering them soon. I’m kicking myself that I didn’t do this when I replaced my wheel bearings a few months ago. But at least we put anti-seize all over everything so they should come back off a lot easier this time.
    And with 33s in my very near future, I don’t see why I wouldn’t do this upgrade.
  4. Feb 27, 2019 at 10:12 AM
    #244
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The caliper should clear the dust sheild. You need to trim the dust shield to clear the larger rotor.
  5. Feb 27, 2019 at 10:40 AM
    #245
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Don’t antiseize the four bolts going into the steering knuckle, they have lock tight type substance on them
    wi_taco likes this.
  6. Feb 27, 2019 at 10:54 AM
    #246
    raco.the.taco
    Chad
    Denver, CO
    If that is the case then I would just go with the correct dust shields because that would be a lot of trimming. I saw somewhere that it was just trimming the notch out where the caliper sits flush with the dust shield.
  7. Feb 27, 2019 at 11:06 AM
    #247
    HeavyThumbs
    HeavyThumbs Well-Known Member
    Phoenix, AZ
    2015 MGM TRD 4x4 OR AC
    Snugtop shell, group buy addiction
    I did this brake swap over the weekend. The improvement is amazing! No more shuddering when the brakes are applied...I was on my second set of warped rotors in 40k miles.
    The whole job took about 3 hours with a hub puller. We failed to get the hubs off without the claw last time.
    Babyjake16 likes this.
  8. Feb 27, 2019 at 11:07 AM
    #248
    raco.the.taco
    Chad
    Denver, CO
    Did you also replace the dust shield?
  9. Feb 27, 2019 at 11:08 AM
    #249
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    You would need to trim the lip off the dust sheild all the way around to clear the rotor which in turn would sacrifice most of the rigidity to not bend toward the rotor and rub on it. Or you could bend it back to and keep the rigidity until you got it caked with mud or snow and it was pushed back toward the rotor and started to rub it possibly with or without noise letting you know it was happening. I am the mod similar to this before the prime of camping season this year except I am going with the 5th gen T4R rotors and calipers for the extra width and heat dissipation.
  10. Feb 27, 2019 at 11:11 AM
    #250
    HeavyThumbs
    Phoenix, AZ
    Yes, I wouldn't be comfortable just trimming the old one. The swap would have been closer to 1.5 hours without taking the hubs off to get them replaced.
  11. Feb 27, 2019 at 12:39 PM
    #251
    1E7DCSB
    1E7DCSB Well-Known Member
    NH
    x2
    i would replace them or take them off. I replaced them with the ones corresponding to the calipers and rotors i used.
    raco.the.taco[QUOTED] likes this.
  12. Mar 16, 2019 at 12:53 PM
    #252
    05Taco4x4
    2TR-FE Enthusiast
    To anyone who's done this and swapped to stainless lines at same time, how many bottles of fluid did you go through bleeding the lines?
  13. Mar 16, 2019 at 1:32 PM
    #253
    HeavyThumbs
    Phoenix, AZ
    I'd have two on hand. I've done both the brake swap and stainless brake lines, and it takes about a bottle each time, best to have extra sitting around.
    1E7DCSB and Drainbung like this.
  14. Mar 16, 2019 at 1:34 PM
    #254
    05Taco4x4
    2TR-FE Enthusiast
    Thanks :bowdown:
    HeavyThumbs[QUOTED] likes this.
  15. Mar 16, 2019 at 2:11 PM
    #255
    1E7DCSB
    NH
    Yeah I agree with 2 pints. I replaced my “s” lines going into the caliper and 1 soft line that the crimp let go on and used just under 1 pint.
    05Taco4x4[QUOTED] likes this.
  16. Mar 17, 2019 at 7:03 AM
    #256
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I buy a quart bottle, and usually use at 3/4 of it.
    raco.the.taco likes this.
  17. Mar 17, 2019 at 7:10 AM
    #257
    raco.the.taco
    Chad
    Denver, CO
    Any recommendation on what dot 4 fluid to buy locally? Napa, Autozone, Advanced Auto, Oreily...
  18. Mar 17, 2019 at 10:37 AM
    #258
    1E7DCSB
    NH
    I get Toyota pints, only because they’re behind me everyday lol
  19. Mar 28, 2019 at 2:18 PM
    #259
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Not sure if i missed this on the thread, but if anyone needs to replace the hard lines that go between the calipers and the brake hoses, here are the toyota part numbers :
    47318-04130
    47317-04080
    i've been compiling parts over the past couple of weeks and hoping to accomplish this upgrade soon...
  20. Mar 28, 2019 at 2:28 PM
    #260
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Those are the part #'s for the original tacoma parts. You want the 4Runner parts since you are going to 4Runner calipers.
    They are 47314-60311 and 47317-60131.
    garciav[QUOTED] likes this.
