2nd Gen DIY Big Brake KIt -OEM parts- Part #'s provided (INSTALLED)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by craigFLA, Jul 31, 2016.
  1. Aug 4, 2017 at 1:04 PM
    #121
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    You could go either way. I would say dump the money in your suspension first then do the brakes afterwards. Our brakes work just fine stock but can always be better.
  2. Aug 4, 2017 at 1:05 PM
    #122
    nudavinci64
    Robert
    Good point, you do need 17" wheels for the 5th gen or you can go with the Tundra setup if you stick with 16" wheels.
    MrCrowntown[QUOTED] likes this.
  3. Aug 4, 2017 at 1:09 PM
    #123
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    @3378jakesr5 this was what I was telling you about, once you get stock mounting points again.
    nudavinci64 likes this.
  4. Aug 4, 2017 at 1:54 PM
    #124
    nudavinci64
    Robert
    My guess there will be an option on what you want. Originally I went with 2" but at the last minute I swapped to 4". You could certainly just get stock length if you wanted. Just depends on the lift setup you have or what you plan to do.
    steveh_2007 likes this.
  5. Aug 4, 2017 at 2:00 PM
    #125
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    Thank you guys. Since the suspension is the most, i should concentrate on that. I can always run on my 16s with an upgraded suspension. Then I can do wheels, then the brakes. Thanks again!
  6. Aug 4, 2017 at 2:10 PM
    #126
    YamaDirtrider
    Josh
    Elizabeth CO
    I want to clarify on the 4th gen t4r upgrade. Do I need to get extended brake lines? I'm only planing ~2" of lift and already have 17" rims.
  7. Aug 6, 2017 at 7:06 PM
    #127
    nudavinci64
    Robert
    Probably not. I would say at 3" you would want to. With your lift it would be up to you but I did it to be on the safe side.
    YamaDirtrider[QUOTED] likes this.
  8. Aug 25, 2017 at 7:40 PM
    #128
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    okay, so I tried to read through all of this and figure out what people are doing for their second gens... seems like there are a few options...
    OP is your parts list what you would recommend for a 2nd gen then? Trying to source parts this weekend and get everything for next weekend. If you'd be willing to hit the easy button for me and post the exact parts and numbers you would recommend for me ill love you long time :D
    MrCrowntown likes this.
  9. Aug 25, 2017 at 7:47 PM
    #129
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    This is lowkey on my mind too... I think it might have to happen before the turbo..
    Rextinkleton93 likes this.
  10. Aug 25, 2017 at 8:41 PM
    #130
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    The Title of the post addresses 2nd Gen specifically, use those PNs which everyone in this thread has used and you'll be fine.
    Bsheriff11 likes this.
  11. Aug 25, 2017 at 9:12 PM
    #131
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    @eccracer104 this is that brake thread I was talking about some time ago. Think I'm going to go this route when I'm due for new pads.
    Drainbung and eccracer104 like this.
  12. Aug 25, 2017 at 11:38 PM
    #132
    nudavinci64
    Robert
    The options are Tundra brakes for 16" or 4 runner brakes for 17" wheels. OP was fling the tundra. I posted on the 4
    5th gen 4 runner setup.
  13. Aug 26, 2017 at 6:35 AM
    #133
    desertjunkie760
    Shane
    Check My Sig.
    Didn't the OP give a 3rd option for Lexus vehicles that gave more surface area than the Tindra setup? I still don't know if wheel size was confirmed.
  14. Aug 26, 2017 at 6:08 PM
    #134
    nudavinci64
    Robert
    Ah I missed that tie are right. The Lexus and 4 runner setup are there same size. I would think the 4Runner setup would be easier to find. tje 2010 - 2015/2016 uses the same rotor size bit different caliper.
  15. Nov 20, 2017 at 4:14 PM
    #135
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    Thank you for posting this! I just finished putting them on my truck. HUGE difference!
    Wessty, MattRRT, tacoma16 and 3 others like this.
  16. Nov 20, 2017 at 7:23 PM
    #136
    watermelons
    watermelons Member
    2006 white Tacoma 4wd
    This is awesome. Planning on doing it myself in the spring
    RIDINRICKY likes this.
  17. Nov 20, 2017 at 7:25 PM
    #137
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Where did you source parts? I trying to find the best price.
  18. Nov 26, 2017 at 11:25 AM
    #138
    wobble
    Ridgefield, WA
    2014 TRD OR
    Napa for the calipers. Camelback Toyota for the OEM parts.
  19. Nov 28, 2017 at 10:29 AM
    #139
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  20. Apr 4, 2018 at 2:05 PM
    #140
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Subbed. Nice work op! I have 16” wheels but need better brakes.
