2nd gen front end parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SaltyWambsgans, Feb 18, 2025.
  1. Feb 18, 2025 at 3:36 PM
    SaltyWambsgans
    SaltyWambsgans [OP] Member
    Looking to do some front work on my wife’s 2011. Hubs, ball joints,rack bushing, control arms. Do y’all have any manufacturers y’all recommend. It is lifts but she’s not doing anything crazy in it.
    Sorry guys, I put rack bearing by accident.
  2. Feb 18, 2025 at 4:08 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World.
    Hubs: OEM ordered online (cost less than brick & mortar dealer), @05Taco4x4 's hubs found here, or Napa (which many report have good bearings but confirm)
    Ball joints: Mostly nobody presses ball joints into existing arms any more. Some maybe but most don't, instead just buy replacement complete assemblies.
    Upper control arms: OEM if lifted less than 2" and don't have caster issues; after-market UCAs otherwise - many vendors for those, depends on other specific needs/wants
    Lower control arms: OEM ordered online unless you are doing other really crazy things with suspension mods
    Moog ain't what it used to be. Dorman is often bottom of the barrel. scAmazon and fleaBay have lots of counterfeits. If you don't like gambling avoid them.
    "rack bearing" - ???whats this???
  3. Feb 18, 2025 at 5:20 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    before you do the work, go ahead and source the cam adjuster bolts for the lower control arms.
    Yours will likely have seized and won't unscrew. Might need a sawzall to get them out.
    Those new carbide tipped sawzall blades are worth the money.
    ZColorado and 1schoir like this.
  4. Feb 19, 2025 at 10:22 AM
    TacoTuesday1
    FL
    hubs and bearings: the guy on here
    rack bearing: never heard of it
    ball joints: should probably just do the whole arms. A stock upper is cheap. Latest new not-fabricated LCA I've seen come out is the Mevotech TTX I believe it's called. The green ones. Haven't tried them.
  5. Feb 23, 2025 at 4:38 AM
    SaltyWambsgans
    Sorry guys I meant rack bushings not bearings.
  6. Feb 23, 2025 at 5:09 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
  7. Feb 23, 2025 at 6:14 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    You will need to replace alignment cam adjusters. Buy OEM. Usually it's just the bolt on one end, and the tube on the other. You probably dont need to replace all 6 parts per side.
    Aftermarket cam adjusters are not great, OEM is best here.
