2nd Gen Kick Pods - Lots of Pics
Discussion in 'Audio & Video' started by azTRD, Feb 8, 2010.
  1. Feb 8, 2010 at 10:52 AM
    azTRD
    azTRD [OP] Well-Known Member
    This is my first attempt at fiberglassing so any and all input is welcomed. I posted this over on the fiberglass forums, but thought some people here might appreciate this build.
    My main goal for this project was to build a kick pod that would take up very little space without sacrificing functionality... and try to make it look as factory as possible. I think the design I came up with will accomplish this goal.
    The pods are being made to house a set of HAT L4 speakers. I'll let the pictures do most of the explanation.
    First step was to cut out the kick panel and attach the MDF ring at the proper angle. I have existing kick panels in my truck and like the sound from their current placement, so I kept the same speaker angles. Essentially the driver side pod is on axis to the passengers left ear and the passenger side pod is on axis to the drivers right ear if that makes sense.
    Next I pulled some grill cloth over and attached it to the plastic with CA glue. I scuffed up the plastic to help with the adhesion. I also drilled holes for the epoxy resin to adhere to as well. I didn't pull the cloth to the edge simply because I couldn't in some areas and wanted to preserve the factory edges as much as possible... I think it's fine, but hopefully this doesn't turn around to bite me. Once the fabric was down I mixed up some resin and soaked the cloth. It took a full day to fully cure. I'm not sure if this is normal, but it seemed to be fine.
    Next I laid the fiberglass down and did some sanding. This process was a little weird for me (I'm not sure why) and I think I could have done a better job, but it seemed to be ok and the pod seems to have a ton of strength.
    Next I laid down some Everglass and began sanding, sanding, and sanding some more with 80 grit. At this point I started feeling good about the way it was tuning out.
    After I got the shape down and smoothed out, I painted the pod with some SEM high build primer. I am rattle canning everything and so for I am very impressed with the SEM.
    With the primer down I found several imperfections, so I sanded out some spots and used some spot putty where I needed.
    This is where I left off. I will lay down some more primer tomorrow and continue to work out the imperfections. My plan is to use SEM texture coating on them, then hit them with some SEM color coat.
    The one thing that I'm not entirely sure about is whether I should clear coat these after the color is down. They will be at my feet so I'm leaning toward putting a clear coat on... I just don't like the glossy finish the clear puts on. I assume they sell a flat clear?
  2. Feb 8, 2010 at 10:53 AM
    azTRD
    Here are the second to final version of high build primer pictures. There were still a couple of imperfections at this point. I am extremely impressed with the SEM high build primer... it really seems to do a nice job and feels like a high quality product. Although it's pretty toxic. I pulled my respirator back for a second to scratch my nose (i had an itch), and the fumes nearly knocked me out.
    Here are a few shots of the pod with a layer of texture coat. I'm glad I did a few test pieces before putting the texture on. This was my first time using this stuff, so it took some practice to get the texture right.
    After the texture was down, I knocked it down a bit with some 400 grit and proceeded to paint.
    I painted the grill pieces with the high build primer and liked the color, so I may keep it this way. I was going to paint the grills the same grey as the pod, but I kinda like the contrast. Here are a couple of shots with the speakers grills in place.
    After getting some input from a few people here, I decided not to put a clear coat on. They seem very durable without the clear.
    So that is pretty much it for the drivers side. Overall I am very happy with the way it turned out. There are a couple of things I would have changed or done differently, but for my first time... I can't complain. This site has been a huge help... what did we do before the internet? I will get some installed pictures here shortly and post them up.
    I have moved onto the passenger side pod. I made a template of the cutout from the drivers side and transferred it to the passengers side pod, so now it's time to get started on that one.
  3. Feb 8, 2010 at 10:53 AM
    azTRD
    Here are a couple of pictures with the pod installed.
    Jacked Burton and Kaiyahzzz like this.
  4. Feb 8, 2010 at 10:55 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    very cool, good job!
  5. Feb 8, 2010 at 10:56 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Holy smokes. well done.
  6. Feb 8, 2010 at 10:58 AM
    CanadianGuy
    CanadianGuy Well-Known Member
    Vancouver, BC
    08 Access Cab 4x4 TRD
    wow thats sick
  7. Feb 8, 2010 at 10:59 AM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    wow man, thats legit. Good job
  8. Feb 8, 2010 at 11:03 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    pretty bad ass
  9. Feb 8, 2010 at 11:29 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Very very nice work! I know who I'll be going to for fiberglassing work! That's the one thing I have yet to try.
    What frequency band are you running the L4's?
  10. Feb 8, 2010 at 11:34 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    That looks damn good! I bet you could even make some and sell them on here.
  11. Feb 8, 2010 at 11:40 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    wow, very nice bro. turned out perfect!
  12. Feb 8, 2010 at 11:46 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Looks factory. Fantastic job!
  13. Feb 8, 2010 at 11:56 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Awesome! Great job!
  14. Feb 8, 2010 at 12:19 PM
    eschmunk
    eschmunk Well-Known Member
    Stuttgart, Germany
    09 Prerunner TRD Off-Road
    GrillCrafter Upper and Lower, Lamin-X Fog Light Covers, Di-Noc Carbon Valence Cover, WeatherTech Digital Fit Liners, Rubbermaid "ActionPacker" containers for bed storage.
    I call B.S. No way is this your first time playing in fiberglass. :) Just kidding, awesome job mang.
  15. Feb 8, 2010 at 12:30 PM
    azTRD
    I'm actually running the L4's HP at 200 without running any tweeters... the L4's have a nice wide range and sound phenomenal. I have L6's in the doors band passed from 50-200 and a pair of Ultra LV6's LP at 50. There is a local Hybrid Audio rep that has this setup along with a local installer... listening to both of their setups convinced me to go this route and I am very happy with the sound.
    Everyone has a different need/ear for car audio... this setup seems to work well for my needs.
  16. Feb 8, 2010 at 12:34 PM
    azTRD
    BTW... thanks for all the comments. I'm pretty happy with the way it turned out... hopefully I can get the passenger side to match. :D
  17. Feb 8, 2010 at 12:35 PM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    Thats looks awesome. Big props to you.
  18. Feb 8, 2010 at 12:48 PM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    Yes, very nice. I've considered trying some L4s in the kicks myself, but haven't have the nerve to try it. This is inspirational.
    Where did you get those rings and grills?
    thanks
  19. Feb 8, 2010 at 12:51 PM
    JohnnyTaco
    JohnnyTaco Is this thing on?
    Los Angeles
    2019 Cement TRD OR 4x4
    OV tune Wet Okole seat covers
    clean job
  20. Feb 8, 2010 at 2:36 PM
    azTRD
    The rings and grills were made by Jon at Handcrafted Car Audio. Awesome guy and great to work with. He already had a template for the L4's, so he was able to cut them out fairly quickly using table router.
