2nd Gen LCA Bushings - Recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFNG, Feb 15, 2018.
  1. Apr 3, 2019 at 5:42 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Tried to get an alignment post install and my left side bolts wouldn't move hardly at all.
    whatstcp and erdub54[QUOTED] like this.
  2. Apr 3, 2019 at 12:35 PM
    fivefoot
    fivefoot Scarlett, Scarlett Tacoma is the name!
    Temo
    Texas Panhandle
    2012 Tacoma TRD Offroad Barcelona Red
    @mtbjohn42 how are you liking the Whiteline bushings so far? I will be rebuilding a set of LCAs I just bought.
    Like what @TacoFNG mentioned, I am too having the same exact issues. Steering wheel is sloppy, alignment is off on drive side, inside tire is wearing out. Clunk when turning right or hit pot holes.
    I'll be replacing the following:
    Lower Control Arms (rebuilding them using Whiteline bushings)
    Upper Control Arms (OEM)
    Inner and Outer Tie Rods (Pro Forged Inner and OEM Outer)
    Rack & Pinion Bushings (Energy Suspension)
    Installing 6112 front and 5100 rear (Bilstein)
    Installing General Spring KC HD leaf springs
    Can't wait to do this in a few weeks!
  3. Apr 4, 2019 at 6:29 AM
    mtbjohn42
    mtbjohn42 Well-Known Member
    Laporte, CO
    2005 Toyota Sequoia
    They have been great. No complaints from me. Everything is very tight and the truck is still alignable lol
  4. Apr 4, 2019 at 7:08 AM
    fivefoot
    Temo
    Texas Panhandle
    Any squeak issues?
  5. Apr 4, 2019 at 8:17 AM
    mtbjohn42
    Laporte, CO
    2005 Toyota Sequoia
    No squeaking. Just make sure you grease the crap out of everything. Toyota doesnt do that from the factory...I have no idea why not
  6. Nov 22, 2019 at 6:51 PM
    kylehorvath
    kylehorvath Well-Known Member
    Kyle
    Humboldt/Tuolumne/Stanislaus
    2007 Access Cab, 4x4
    Over GVWR and I keep adding more metal
    Trying to hunt down a mystery clunk!
    I'm looking to do one of a few things:
    -Rebuild my LCAs with new bushings
    -Replace with Total Chaos or Camburg or Dirk King, orrrrrr....
    -Solid Axle (ok, not really the route I can justify)
    I'm pretty sure it is my stock left LCA bushing that is bad. It's probably not ECGS, as the sound is the same in 2WD vs 4WD. It's probably not UCA, they are new Camburgs and are greased. It's not the sway bar, it's long gone. The clunking over small potholes and washboard might be because of a loose cam bolt, but I've torqued them to spec (96 ft lb). I'm left with thinking it's my LCA bushings.
    I have King Extended Travel 700 lb 2.5" with RR (should have got the compression adjuster, dangit). I also have TC skids on my LCAs, so I really don't want to replace.
    If travel and ride will be improved with new LCAs without needing to replace my current COs, I may go that route. BUT, if there are recommendations on bushings and it's an easy replacement, i'm open to suggestions.
  7. Jan 17, 2020 at 10:04 AM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Same exact boat...
    Kylehorvath any updates on this?
  8. Jan 17, 2020 at 2:11 PM
    kylehorvath
    Kyle
    Nope, holidays and trips.took priority! Will order whitelines soon
  9. Feb 23, 2020 at 2:51 PM
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    Do you torque the cam bolts to the OEM recommended value when using the whiteline bushes?
  10. Feb 23, 2020 at 4:44 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes
    zippo88[QUOTED] likes this.
  11. Apr 14, 2020 at 8:44 AM
    jdiola
    jdiola Well-Known Member
    jay
    Echo park los angeles
    13 tacoma dcsb off road
    Ovtune, anytime locker mod, pelfrey hybrid bumper, pelfrey rock sliders baja designs s8 and sqaudron pros, group 31 interstate battery with TW memeber coupe trd battery strap, osram 100/90 watt headlight bulbs, hkb voltage booster, meso 3 pod 3rd brake light, archive hammer hangers at the helm motorcycle holder/bed stiffiner prinsu rack gfc superlite rotopax 2.5 gas 2 water sua deaver hd springs with icon hydro bumps 12” fox 2.5 dcs w/ accutune on archive shock relocation ext icon cdc front coil overs jdfab 2.25 lt w/currie axles fox 2.5 front bumps jdfab double shear uca jdfab spindle gusset bypass shock hoop with icon s2 falken wildpeak 265/75-17 carhart seat covers
    you could also try a limiting strap. sometime the shock bottoms out over small speed bumps makes a big clunk
    TireFire likes this.
  12. Dec 10, 2020 at 8:41 PM
    Full_enchilada
    Full_enchilada Well-Known Member
    BC Interior
    2023 SR5 Celestial Silver DCLB
    I know this thread is old, but i currently have super terrible LCA bushings on my truck and I'll try to post a vid showing what it sounds and looks like. (Spoiler alert, IT'S BAD)
    kylehorvath likes this.
  13. Dec 15, 2020 at 11:00 AM
    Full_enchilada
    BC Interior
  14. Dec 15, 2020 at 2:10 PM
    jdiola
    jay
    Whitelines, icon, powerwerks, they are all polyurethane bushing. Which are stiffer but bind and make more noise. I think the alignment puts all the stress on these bushings. Taller the lift the more stress. I don’t think urethane is good for this type of stress. I would go oem for these. Unless you go with the pivot kit from @81Trekker @jdfab then the stress is relieved.
  15. Feb 23, 2021 at 11:24 AM
    #35
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Are there Delrin bushings available that fit?
  16. Apr 15, 2021 at 10:29 PM
    #36
    fourwhlcrzy
    fourwhlcrzy Member
    Daren
    08 taco, 93 hilux
    lifted
    I just got the Problem Solving bushings https://psbushings.com/toyota-tacoma/ and the bolts don't fit the bushing sleeves. rear bolt too loose and front has a sleeve on it, too big. Anybody else try these?
  17. Apr 16, 2021 at 9:34 AM
    #37
    TireFire
    Olympic Peninsula
    Seems like they are problem creating bushings lol
  18. Apr 16, 2021 at 11:46 AM
    #38
    fourwhlcrzy
    fourwhlcrzy Member
    Daren
    08 taco, 93 hilux
    lifted
    Armstrong distributers ( for PSB bushings) was very casual is saying" oh yeah, the tacoma and 4runner have the same bushings but the bolt sleeves are different. I'll send you new ones" WTF, my truck is apart, and looking on rock auto, a 4runner takes the same bushing. I'll see what they send
  19. Aug 12, 2024 at 12:17 PM
    #39
    KBraden79
    KBraden79 Active Member
    2012 trd sport Tacoma
    I have a 2012 trd sport Tacoma
    JBA UCA
    TRQ LCA
    I have just changed out my wheel bearings that I bought from @05Taco4x4. But I am still having a problem with a popping noise when I back up and turn my wheel and if I go over a speed bump. I can only assume at this point it is the LCA bushings or alignment bolts. Can anyone help?
