2nd gen LED roof light mount
Discussion in 'Lighting' started by Bobber Bill, May 26, 2012.
  1. Jan 14, 2014 at 2:51 PM
    #181
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Badass, finally
  2. Jan 14, 2014 at 5:45 PM
    #182
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Has anybody mounted a 50" bar on this?
  3. Jan 14, 2014 at 5:52 PM
    #183
    Large
    Large Red
  4. Jan 14, 2014 at 6:01 PM
    #184
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Have always loved these bars but the OP does say bars as big as 47.5...so idk if it will fit :notsure:
  5. Jan 14, 2014 at 6:06 PM
    #185
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Might fit the curved 50"...crossing fingers
  6. Jan 14, 2014 at 6:07 PM
    #186
    Jerez
    Rod
    Ontario Ranch
    Estock
    Yea that's possible...hopefully will can come in and maybe explain if it's doable
  7. Jan 14, 2014 at 6:09 PM
    #187
    SoCalTacos
    socal
    You could always make some custom tabs that bend outward to accommodate the larger size...shouldn't be too big a deal?
  8. Jan 14, 2014 at 11:33 PM
    #188
    Bobber Bill
    Bobber Bill [OP] Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    This is a possible solution. I can't say conclusively at this point what it will take to mount a 50" bar, either straight or curved because there are so many different brands/models out there.
    The mounts are right about 47.5" apart. The way that my racks were designed allows you to use the provided tabs to mount anything within that width.
    Another possible alternative is to do away with the round tube and tabs altogether. You can mount an LED bar right up to the side brackets by drilling 2 small holes and bolting them up. You can bend the brackets in or out to match your LED bar size.
    I have sold a few sets of the side brackets only for people to do exactly that. It is up to the buyer to figure any of that out. I may still have 1 or 2 sets available. I will check tomorrow.
  9. Feb 20, 2014 at 4:29 AM
    #189
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
    Subbed
  10. Feb 20, 2014 at 8:41 AM
    #190
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    The blue tacoma former member Johnw has bombers mounts that he bent I believe to fit his 50" rigid. I could ask him for pics if y'all are interested
  11. Mar 2, 2014 at 10:56 AM
    #191
    Whitelighting10
    Whitelighting10 New Member
    2010 tacoma
    i NEED this bad but cant get a reply!! light bar collecting dust :(
  12. Mar 9, 2014 at 6:00 PM
    #192
    Carrionman
    Carrionman Well-Known Member
    James
    Eastern NC
    2013 4x4 v6
    Wishing I had not put the factory roof rack on after seeing this, does not look as if this would work seeing as the holes to bolt it in are quite taken. SMH
  13. Mar 23, 2014 at 7:47 AM
    #193
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    On an access cab, can the drip channel trim be reinstalled atop this bracket's mounts?
  14. Mar 26, 2014 at 5:23 PM
    #194
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I will take one if you still have one available
  15. Mar 27, 2014 at 11:34 AM
    #195
    Bobber Bill
    Los Angeles, CA
    Yes, but it will need a little trimming. Access cabs and single cabs will also require you to drill four 1/4" (6mm) holes. Double cabs are ready to bolt on with no drilling.
  16. Mar 30, 2014 at 8:29 PM
    #196
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Anyone that has a lightbar up top how do you run the wires down? I was told along the side of the windshield which is a good idea, the light bar sits back further than that rain channel.. Just wondering the best way to minimize the amount of wire that is visible. Thanks!
  17. Mar 30, 2014 at 8:36 PM
    #197
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    its really easy...just run it behind the mount then down the window....cant see mine at all
  18. May 7, 2014 at 6:42 PM
    #198
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Noooo!
  19. May 20, 2014 at 12:24 PM
    #199
    rtgreene10
    rtgreene10 Well-Known Member
    Fl cracker
    4x4 turd
    Any word when these might be available again???
    Screw my hellas
  20. May 21, 2014 at 8:48 AM
    #200
    cstallings
    Arkansas
    x2
