2nd Gen OR Second Battery Mount
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Iggy, Feb 29, 2016.
  1. Feb 29, 2016 at 4:34 PM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Hi TW! I have been developing a battery tray for a while now. I am out of the development and testing phase and ready to bring these into production.
    I currently have 4 pre-production tray kits ready to go. The only difference with the final version is additional cut outs for zip ties.
    As of now these are very easy to install on OR models with ATRAC 2005-2011 that do not have the emissions pump. 2012+ Models I am finishing up relocation brackets and will be offered with the kit soon.
    Second Battery Tray
    Included Hardware
    Purpose:
    • Adds a second battery to your Off-Road model Tacoma. The largest battery that fits in the passenger side location is a Group 27 (Same as stock). A group 31 is too large and why limit yourself to a small group 34.
    • Neatly organizes all your auxiliary electric needs by having previsionary space for a relay control box, breaker and battery control module.
    • Clean and aesthetically pleasing, this tray and kit follow the lines and appearances of an OEM setup.
    Specs:
    • Designed for the Optima Yellow or Blue Top group 27 battery.
    • Provides mounting location for a Blue Sea ML-ACR (bracket with threaded holes and stainless torx bolts)
    • Neatly arranges a mounting location for a Bussmann RTMR relay and fuse box.
    • A cut out for a Bussmann surface mount breaker
    • Custom cut 99.9% copper bridge to connect RTMR and breaker
    • Delrin top battery tie down. Non conductive and will not cause a short if battery were to come loose.
    • The tray is water jet cut from 1/8" steel and powder coated black
    • Hardware (nut, bolts, mounting torque screws, and battery tie down rods) are all marine grade stainless.
    • Clears aftermarket hood struts.
    Compatibility:
    • Fits 2005-2011 Off-Road ATRAC Models with no relocation and minimal fitting.
    • Fits 2012-2015 Off-Road ATRAC Models with relocation of emission pump (kit coming soon)
    • If your Tacoma has this unit, the tray will not work :(
      Not my Photo:
    • 2016+ 3rd Gen Off-Road Models may fit, but I require a test fit first
    Pricing:
    • $175 Shipped CONUS for the 4 preproduction kits. Only while supplies last.
    • Standard pricing will be $225 shipped CONUS.
    Future Additions:
    • Completely wired and setup RTMR and Blue Sea ML-ACR with my switch panel into the cab. I will make this available shortly once I can finalize the wire lengths and pricing.
    Area For ML-ACR
    Bussmann RTMR and Breaker mocked up with our custom cut copper bar (RTMR and Breaker not include with base kit)
    Blue Sea ML-ACR and RTMR Fully Wired up
    Installed on the truck and shows how neatly the kit organizes everything.
  2. Feb 29, 2016 at 4:36 PM
    Iggy
    Northern CA
    Check out the build
    Here's the thread @ramonortiz55 created for his kit.
    I should have a video illustrating how to install the kit on an pre 2011 OR model soon.
    ExpyTaco and T4RFTMFW like this.
  3. Feb 29, 2016 at 4:38 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    OK, you have my interest.... again!
  4. Feb 29, 2016 at 4:42 PM
    Iggy
    Northern CA
    Check out the build
    I see you have a 2012. I am finishing up the brackets to relocate the emissions pump. I should have those made to test soon. I'm hoping to make them out of stainless to avoid having to power coat them.
    kalieaire likes this.
  5. Feb 29, 2016 at 4:58 PM
    taczilla
    Marc
    2016 RAM Rebel
    Hmmm... mine is a Sport, does that make a difference?
    ... and I haven't installed all the stuff I have yet, 'cause I was waiting/searching for options on a dual battery set-up (and better weather).
    This plate, a relocation bracket for the pump, more cable, and a ML-ACR could get pricey.
    I already have this:
    Oh! ... and powder coat may be unecessary, wrinkle paint works just as good.
    GHOST SHIP likes this.
  6. Feb 29, 2016 at 5:00 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    sports and non atrac ORs have the ABS pump in that locatioin
  7. Feb 29, 2016 at 5:01 PM
    taczilla
    Marc
    2016 RAM Rebel
    K... thanks!
  8. Feb 29, 2016 at 5:02 PM
    Iggy
    Northern CA
    Check out the build
    So close man! All the Tacoma's expect for the OR's have a different type of brake system that takes up room in the passenger side wheel well. The OR's have a Hydrostatic brake system so they don't have the ABS module on the passenger side. This tray bolts into the studs that hold onto that ABS equipment.
    In the next few weeks though I should have something you maybe interested as well. Stay tuned.
  9. Feb 29, 2016 at 5:03 PM
    Iggy
    Northern CA
    Check out the build
    Thanks! Beat me to it!
  10. Feb 29, 2016 at 5:07 PM
    Iggy
    Northern CA
    Check out the build
    Essentially if you have this (not my photo) my dual tray will not fit.
  11. Feb 29, 2016 at 5:08 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    That exact thing is what i have too :/
  12. Feb 29, 2016 at 5:10 PM
    Iggy
    Northern CA
    Check out the build
    It's the only bummer with this kit and this location in general. The only other approach is to relocated the steering pump reservoir and install a smaller group 34 there, or relocated the second battery to the bed.
  13. Feb 29, 2016 at 5:10 PM
    ChamYota
    Cam
    The bed is looking more and more like what i'll have to do. Just no room in the engine bay for the OR models it seems.
  14. Feb 29, 2016 at 5:13 PM
    Iggy
    Northern CA
    Check out the build
    I think that's the way to go. Take a look at one of the last few pages in my build thread. I had a aluminum captains box built to hold my compressor in the bed. Something like that would be nice to hold 1 or 2 additional batteries and all the management equipment.
    ChamYota[QUOTED] likes this.
  15. Feb 29, 2016 at 5:24 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Looks great! Saw it in person this weekend and it is super clean. If my truck didn't have that brake stuff in the way I'd go this route.
    +1 for another great product from @Iggy. :thumbsup:
    Iggy[OP] likes this.
  16. Feb 29, 2016 at 5:34 PM
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Very nice product, wish I could run one. Props regardless!
  17. Feb 29, 2016 at 5:36 PM
    2015whitetaco
    2015whitetaco Well-Known Member
    Pleasant Hill
    2000 Ford F-250 7.3 powerstroke 96 4runner POS
    Im in agreement with @tacomgee I would totally go this route but I have a base model and no room up there
    Good looking mount though
    Good luck @Iggy.
  18. Feb 29, 2016 at 5:41 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    Not all ORs are like that. Only the ORs that have atrac don't have the abs block. I have an 06 OR and have the abs block there
    Iggy[QUOTED][OP] likes this.
  19. Feb 29, 2016 at 5:48 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  20. Feb 29, 2016 at 7:04 PM
    Iggy
    Northern CA
    Check out the build
    You're right. I will edit the OP. Thanks!
