2nd Gen Reinforcement Plates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WrestlePSU24, Jun 21, 2021.
  1. Jun 21, 2021 at 3:11 PM
    WrestlePSU24
    WrestlePSU24 [OP] Member
    Austin
    2005 Tacoma
    Hey does anyone know where to get prefabricated reinforcement plates for the frame of a 2nd gen?
  2. Jun 21, 2021 at 3:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, but they are just that -“Reinforcement Plates”
    They reinforce an already “good” frame.
    They are not patch plates. They do not make a bad frame- good again.
    If this is what you are looking for, I haven’t seen any patch kits….yet.
    Here is the reinforcement plate kit.
  3. Jun 21, 2021 at 3:21 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  4. Jun 21, 2021 at 3:24 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
  5. Apr 23, 2024 at 12:50 AM
    TacoTuesday1
    FL
    researching boxing the frame
    curious to know if anyone’s come to the same opinion that dimple holes are better
    seems only a few options are that way
    so that the inside remains when done and in the future
    -paintable
    -coatable
    -cleanable
    -serviceable (counter hold a nut etc)
    Vs solid inaccessible plate
  6. Apr 23, 2024 at 1:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not necessarily dimpled but you'll be adding more strength by having holes to plug weld.
  7. Apr 23, 2024 at 1:03 AM
    TacoTuesday1
    FL
    gonna have to look up what that means lol
    I’m guessing ability to access and weld things from the back side
    even better
    I was going at it from a wrenching standpoint
    Examples
    -sliders I counter hold nuts behind frame to install
    -washing including 360 nozzle I shove in the frame with garden hose to spray it out
    -spraying fluid film straight out the can or using their tube attachment
    all of which makes seem dimple holes better, while still adding a net increase in strength from stock
    not to mention potentially welding more, or bolting more, things onto the frame
    If that’s even recommended
    Like a mud flap bracket holder
  8. Apr 23, 2024 at 1:07 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Depending what part of the frame you reinforce, I can't see the need to add anything anywhere with the exception of sliders.
    The area that often gets reinforced is the rear part of the frame above the leaf pack, and with most kits consisting of outer plates, you'll have access to anything on the inside of the frame like normal (maybe a bracket for a line or something).
    Can't think of anything else that would possibly need to get mounted outside?
    Worst case you just make/cut your own if you need one side or area shortened for a future project otherwise they're all pretty similar.
