2nd Gen Tacoma 4.6 V8 1UR-FE and GX powertrain Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpanibratets, May 22, 2022.
  1. Jun 11, 2023 at 7:39 PM
    #661
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    What’s the deal with that?
    Jdpsurf likes this.
  2. Jun 12, 2023 at 7:33 AM
    #662
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I don’t know. They’ve been black listed for several years. They were pretty active when I joined the forum over 10 years ago.
  3. Jun 12, 2023 at 1:46 PM
    #663
    ryanbitt
    ryanbitt Wherever you go...there you are.
    Hutto TX
    07 DCLB 4x4
    Wouldn't you like to know!
    This whole thread is really impressive man! The attention to detail is Next Level Stuff! Can't wait to see it complete and to hear the V8!
  4. Jun 16, 2023 at 1:42 PM
    #664
    dpanibratets
    dpanibratets [OP] Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    Right side harness is all hooked up and I taped off the rear hvac controls. I will also remove fuses and relays associated with rear hvac. I also found the power to the rear view camera and separated it from the main harness to have it ready for tailgate wiring. I decided to use aftermarket 12v camera because the tacoma sends 6v of power to the camera when in reverse. The lexus sends 6v when you turn on accessories and on another wire 12v when you are in reverse. I know I could make it work with a relay but I don't want to deal with it. Plus I already prewired a yellow RCA on the left side. Also I found the tacoma license plate light harness and wired in to the lexus license plate light wire. I got to wrap up some wires by the rear passenger door and the we move on to the ENGINE BAY!
    20230616_132417.jpg 20230616_132426.jpg 20230616_132514.jpg 20230616_132451.jpg 20230610_202744.jpg 20230610_202736.jpg
    HWI, dumontrider, Greyhome and 9 others like this.
  5. Jun 18, 2023 at 12:17 AM
    #665
    dpanibratets
    Denis
    Vancouver, WA
    Cancelled out both knee airbags second row seat airbags and 2nd row seat belt pretensioners using resistors. The gx460 has a 5th airbag sensor under the 2nd row bench closer to the right side. I found the perfect spot for it where the under seat storage won't touch it. It is oriented like this in the gx. I also worked on running more amp/stereo wiring. I need one more RCA cable and the amp will be pretty much all wired up.
    TnShooter, dumontrider, HWI and 2 others like this.
  6. Jun 20, 2023 at 8:02 AM
    #666
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I can mail you some brand new RCA cable for free if you want.
    TnShooter likes this.
  7. Jun 22, 2023 at 12:35 PM
    #667
    dpanibratets
    Denis
    Vancouver, WA
    Thanks but I'll just pick some up they are pretty inexpensive.
  8. Jun 22, 2023 at 12:41 PM
    #668
    dpanibratets
    Denis
    Vancouver, WA
    Working on getting the headlights wired up right now. I decided to throw in the gx radiator just to see how it fits. If fits perfectly and bolts right in! And yes I will be getting a new one because the top hose fitting is cracked. This is just for mock up purposes to put the engine in the right spot.
  9. Jun 22, 2023 at 2:20 PM
    #669
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Is the GX radiator actually bigger than the Tacoma's?
  10. Jun 22, 2023 at 2:51 PM
    #670
    dpanibratets
    Denis
    Vancouver, WA
    By the looks of it it looks taller. I will measure when I get a chance. My biggest concern is the transmission fluid lines that good up to it.
    saf023[QUOTED] likes this.
  11. Jun 22, 2023 at 4:38 PM
    #671
    henryp
    Henry
    Montana
    You can always use an aftermarket trans cooler. If you do any towing you’ll find the stock set up lacking. Some YouTube guys show what’s worked for them on the GX.
    https://youtu.be/TyeOWkhwsfs
    but then again, moar $$$$
    dpanibratets[OP] likes this.
  12. Jun 22, 2023 at 5:27 PM
    #672
    dpanibratets
    Denis
    Vancouver, WA
    I don't really plan on doing much towing and since I have to buy a radiator I figured buying a CSF heavy duty radiator would be a good choice. If I need the additional cooling later on I will do a standalone atf cooler but for now I'll see how the CSF will handle it.
    TnShooter and henryp like this.
  13. Jun 23, 2023 at 9:42 AM
    #673
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The GX radiator should be about 4" taller and about 1/8" thicker I believe.
    Jeff
  14. Jun 23, 2023 at 12:10 PM
    #674
    saf023
    East Coast
    You probably know but CSF sure seems to makes very high end prodocuts. :thumbsup:
    My limited experience with them is the quality, workmanship, and performance of a set of reinforced intercooler bricks they co-developed with DMS for a Supercharged LS9 Chevy. The product has been outstanding. I needed something that would withstand the increased boost pressure and thermal load of aftermarket pulleys for a Supercharged LS9 engine. The manufactured end-product also clearly looks like it came out of a CSF shop.
    My interest is if you buy a CSF radiator, will you go with the one they sell for a Tacoma or the GX? From your response, is seems that although the GX radiator "bolts right in", the location of the "transmission fluid lines" may not be as straight forward. Is that correct?
    After seeing what you've accomplished, You're the Man! Thank in advance!
  15. Jun 23, 2023 at 12:41 PM
    #675
    dpanibratets
    Denis
    Vancouver, WA
    Yes I heard good things about CSF also.
    Well I have the oem transmission lines from the GX so I figured I'd just use them along with a gx radiator. The oem lines run from the right side of the bellhousing/transmission right past the engine oil pan, cross under the radiator ran and hook up to the left side of the radiator. So far, because the width of the frame rails is virtually the same, every has been fairly straightforward. I am so happy that the Gx radiator bolted in, I thought for sure I would have to modify the core support but turns out I don't.
  16. Jun 24, 2023 at 5:05 PM
    #676
    dpanibratets
    Denis
    Vancouver, WA
    Headlights are wired up, more or less. I am going to attempt to weld the engine mounts in on monday!
  17. Jun 24, 2023 at 6:34 PM
    #677
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Sure does look funny without it’s fenders lol!
    Greyhome and dpanibratets[OP] like this.
  18. Jun 24, 2023 at 8:49 PM
    #678
    dpanibratets
    Denis
    Vancouver, WA
    Welded in some bolts to hold the heater core lines. Had to get that out of the way before the engine goes in. And then I noticed that both ac lines will need to be modified because the ID is different on both tubes.
    dumontrider and not_nick like this.
  19. Jun 24, 2023 at 8:51 PM
    #679
    dpanibratets
    Denis
    Vancouver, WA
    Also it is interesting how they use 3UR heads on 1UR. I wonder if the 2UR also has 3UR heads.
  20. Jun 24, 2023 at 9:02 PM
    #680
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    the only thing that's different between the 1ur, 2ur, and 3ur is the Stroke. the bore is the same between the 3 engines. so using the same head castings on all 3 would make sense especially to cut costs
